Charged AC not blowing cold
Greylin
So a couple summers ago, my ac was working intermittently before not blowing cold completely. The AC is properly charged with the coolant but the AC will just blow air the same temp as the ambient temp. Hot air works fine. Is this a bad compressor, condenser, etc. Any help would be appreciated.
TheAutumnWind
You have gauges? What readings are you getting high and low side?
Is your compressor kicking on at all?
Do you have a scan tool that can read error codes? Could be blend door related possibly.
LuLu
Mine was still not blowing got cold air after having the system recharged. Repair shop says there is no signal being sent to the compressor or clutch to engage.
$325 later I’m being told I need to replace the ECM. Really? Replace the ECM because of the a/c?
No problem with the heating
RST Dana
EMT/First Responder Firefighter Supporting Member
OH
First off, what is your ride? Kx22 have issues and and extended warranty to cover condenser replacement if still within their coverage limits.
TheAutumnWind
Sounds like a clutch switch... thats like a $20 part. Unplug the harness to it and stick a paperclip in it and see if the clutch engages. I had this issue recently with my OBS
What year is your truck?
G
Greylin
its a 2001 gmc yukon. blend door works properly its the first thing i checked. i can try the code reader to see if it says anything. when AC is on it seems like the compressor is trying to work but it doesnt change the temperature of the air at all, i just get whatever temp the air is that it pulls in from outside. Doesn't change if i have it recycle cabin air either.
DenaliReyes
Detroit, MI
Mine is the same problem. I have an 05 denali xl 6.0. AC was empty, I paper clipped it to get it going then charged it. It worked for a day. Now it's hot air. And I hear a hiss every 20 secs. It's like the compressor starts then shuts off.
I havent plugged it to dual gauges yet. Have not checked the doors actuators. I figured the clutch was stuck but I'm the magnet worked well with the wire/paperclip trick.
I was going to drive it with it on. But dont want to over charge it.
Will follow your post and see if it helps.
TheAutumnWind
If it wss empty it has a leak. Did you fix the leak? Replace the accumulator and orifice tube?
Put gauges on it and report back.
G
Greylin
So I just bought a clutch switch and replaced it. Had no effect.
G
Greylin
so after installing the new clutch switch onto the compressor and it having no affect, it seems that the clutch plate isn't engaging regardless of wether AC is on or not. I used a paper clip on the wiring to see if that would engage it and nothing happened. Voltage to the relay for the AC is at 12V, i tested the voltage of the wires going into the clutch switch and read approx 2V. is that a problem?
TheAutumnWind
Not sure what reading you should see @ the clutch switch. The clutch not engaging is definitely a problem. If a new switch and/or paperclip have not solved it I would suspect the clutch.
Keep in mind I am far from an expert on this. I assume one will chime in here shortly.
Mooseman93
I have an 01 also and the a/c idler tensioner pulley has failed twice. The last one was only about a year old so I didn't suspect it immediately when the a/c started underperforming. It would work ok enough driving around but sitting still it blew warm. Replaced the fan clutch and of course checked the charge. Finally I found that the tensioner just wasn't keeping the belt tight enough. All good since then.
Fjs0001
You should see 12 volts at the compressor. My AC stopped working and I measured 12V at my compressor, but it wasn't turning on. I hooked a battery directly to the compressor and it worked perfect. I cleaned my connector and it started working correctly.
BigMac
Might have the pressure switch replaced on the Evap Canister. It senses the temp in the cabin (converts it to pressure) and it turns the compressor on and off. Easy fix.
DansOtter
North Carolina
Hey Greylin, did you ever resolve the problem? I'm having the same issue.
I've already replaced most components on the interior; blend door, HVAC control, aspirator sensor, auto HVAC sensor. Just this week the compressor stopped engaging. Of course... now that it's almost July.
Flingflanger
Not to belay the obvious, but have you tried this?
When i bought my 'Hoe, the original owner thought the AC was just broken after he dumped a bunch of money in it and the AC still didn't work. I did the reset procedure and its blown cold ever since.
DansOtter
North Carolina
Yeah I did that when I replaced the blend door actuator and everything worked great for a while.
Problem I'm having now is that it's not kicking on the AC compressor, and my freon is full. But it's intermittent and I can't duplicate it. I'm hoping the pressure switch that a few folks mentioned here would do the trick. If not, I have no idea where else to look.
Drewphil
