Can i remove these from the suspension??
Hey so i wanted a more level look in my truck and i was thinking why cant i just remove the upper and lower spring isolators on the rear coils?
Zed 71
Pacific NW
Just my opinion, but the springs would transmit more vibration/noise into the cabin. Not sure if there would be a mechanical issue.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
your talking about the thin rubber pads on top and bottom? Yes, it's fine. You might get a little squeak going over bumps or something, but it's fine.
Administrator
squeaks like that annoy the crap outta me but it's not my ride :shrug: I vote that you're much better off just buying shorter springs and some shock relocation brackets and call it a day.
Modded
That Guy
Leave them in. When I removed mine I noticed a .2" height difference at best and did have a squeak here and there.
JKmotorsports
Austin, TX
Pulling isolaters wouldn't be worth it IMO. Plus, after some time, the rubbing of metal to metal will wear away the paint from both coils and frame. No paint = bare metal. Bare metal = rust and corrosion.
Modded, trucks looking good.I haven't seen it with the blk wheels and grille.
Modded
That Guy
Thanks :Handshake:
You and a few of the other founding members have been MIA for the last year?
I'm guessing you guys are just busy with life.
fishcop076
