Camaro SS, track trips, build pics etc.
01ssreda4
Quick little update and a temp delay. First, Ms Jane posted the pic she took at the track the other day, go like her page on FB, she takes good starting line pics.
https://www.facebook.com/Jane-Baker-Photography-1520799948220011/
Also another little short clip/pass from two weeks ago located in the middle of this longer video.
So the track decided to have a formal reopening friday night, prep and I think they got one side of the timing system going. Here is the video:
However, I was not there. I found a deal I couldnt pass up and skipped the track.
It's awesome that you have a track not far from you. I'm 3 miles from State Capitol and I rarely ever get a chance to go any more. :(
01ssreda4
On board air and boost leash is installed and working well.
Went to load the car and there was a massive exhaust leak.....
Tubular front came in handy. 1 hour fix and the track day wasn't ruined.
Tow ***** doing what she does.
I just wanna do race car shit with my race car friends.
Monkey business.
Long story short, one of the walbro 450s died. One pump, 12 psi on e85, 10.3 @ 90mph letting off after the 8th. Man she felt good though. New pump and we will try again.
01ssreda4
The last time out i had no boost controller and was on wastegate only which had a 7psi spring, and the car made exactly 7psi. This time i put 10 psi on top of the gates and it made 14psi. Anything over 12 the afr would go in the 13s and injector duty cycle went over 100% which indicates its out of fuel. When i tested the pumps one wasnt running, so i called it a day. And yeah, it felt way better there then at 7psi.
Dead pump or wiring/relay/etc.?
Better than dying during a run at WOT and boost!
01ssreda4
Pump if i could guess. I could count on one hand how many relays ive seen fail in the last 20 years of working on cars.
