Breaking the Bead on a 22"
bad_idea
So... I have a 2018 Yukon XL Denali with the 22" chrome snowflake wheels. I picked up a set of 20" OEM wheels off a 2022 Sierra. The previous owner of the 20" wheels had a tire shop break the outer bead and pull his sensors. This got me thinking, as I am a cheapskate... I could do the same with my old wheels, swap the sensors over, and air them up. The balance should be good still as the inner bead wasn't broken - the tire/wheel orientation are still the same.
I don't have a tire machine, but I have broken down tires by hand in the garage with the usual MCGuyver solutions. How much hell you all think I will go through breaking the bead on that 22" wheel? Anyone have experience breaking them in the garage? Trying to save the $50 or so of a shop doing it for me.
Also, any ideas what I can sell the 22" chrome snowflake wheels for? One has a leak on the outer bead due to corrosion on the wheel (tire shop already slathered some sealant on it once). The rest are in fair condition, no curb rash and minor pitting/scuffs that you can only see with a close inspection.
B-train
For starters, if you break the bead in the wrong spot you'll get the joy of buying a new TPMS. Also, why risk damaging a nice aluminum wheel to save $50? I see your point, but I wouldn't go the tire iron way on these new wheels.
Have a shop break them down, wire wheel the bead sealing surface nice and clean and pop in NEW sensors. If yours are from 2018, then just get new ones and sell the other set complete. If they aren't all corroded, with OK tread, they probably are worth $600 easily on FB.
k_arnold72
If you youtube it there's a few ways to get it done with a jack at home. But it's easier on thicker tires. 22s with this aspect ratio are borderline low profile. So you're risking damaging the wheels or sensors, as stated above.
My shop typically uses the bead breaking method to install new TPMS sensors. The first few times that they did this on my 20" wheels, I had bead leak afterward and a return visit to fix. Since then, they break the entire bead on that side of the tire, clean the rim's bead with a an air tool with a very mild abrasive, apply bead sealant, and then pump up the tire and re-balance it. This change saves us both the time for a second appointment.
B
bad_idea
I attempted to break the bead tonight on one of the wheels. No bueno. I placed the wheel/tire on the floor of my garage, put the foot of my high lift jack in on a board on the sidewall, put the lift foot in the receiver hitch of my jeep, and jacked it up/down. Lifted the jeep off the ground without the bead breaking.
The tires are slap worn out, so I used a 3" hole saw to make an access window in the tread to remove the sensor. Soon enough I will list a set of 22" snowflakes in fair condition, tires no good. :lol:
slupie
Bartlett, IL
Where are you located as I might be interested in your snowflakes without tires.
CMoore711
This just seems like it has your username all over it… @bad_idea.
(Sorry I had to…)
In all seriousness I wouldn’t risk potentially damaging a rim, tire, or TPMS over saving $50.
B
bad_idea
(Sorry I had to…)
Ohh, it's done! I used a 4" hole saw in the center of the tread beside the valve stem. It worked great. Absolutely no damage to the wheel, but plenty of damage to the (worn-out) tires.
The wife and I are happy with the new wheels/tires.
CMoore711
You should have mentioned you were more than willing to sacrifice the tire to accomplish this!
Suggest keeping the rubber on the rims if they are shipped to you, despite the extra shipping cost. I had rims sent to me without tires on them; one was dropped and bent the lip despite plenty of padding.
B
bad_idea
I sold the wheels for $850 on Marketplace yesterday. I had over 50 people contact me about them with ~10 ready to buy them for full asking. I was asking $750, someone messaged me offering $850 if I would hold them for him. Amusingly enough, I had plenty of $400 offers too.
