BREAKING: GM is officially recalling the L87
Scarey
The oil pressure may be slightly higher however I think the variable displacement oil pump design may modulate the pressure a bit. With 0W40 in my engine at idle around 35 PSI, while cruising around 1600 RPM about 45 PSI. The problem I feel with the 6.2l is 0W20 may not hold up to higher heat well before it thins out on long highway runs. One the oil starts to warm up over 212F/100C the HTHS starts to drop, then you have a vicious cycle. Once the oil starts to thin, less protection and probably more heat generated.
I personally see nothing good coming from 0W20 a High Torque, lower RPM engine operation propelling 6000+ lbs vehicle.
At a stop light I see 15-20psi and cruising about 45-50.
Stbentoak
How did I not think about this before?
Genius
I drive mine up on ramps. I don't trust my life on a valve that could fail or change its mind while I'm under it.....
Also I see this fuel dilution mentioned quite a bit, but every single oil analysis I've seen posted gas or diesel, refutes that. If that's such a big deal post up a few analyses that show excessive fuel dilution....
Vladimir2306
I have already written about this several times, there is no dilution of oil with fuel. Oil tests confirm this, moreover, we have a sensor for the presence of fuel in the oil on the engines, it would begin to swear if fuel standards are exceeded
BacDoc
Vero Beach Florida
It's because there's a lot of 'i feel' in this thread and almost no 'i know'
This is true!
Maybe a new thread on common denominator for 6.2l failure.
So far, after reading a lot about this the only thing I have seen is most failures are at highway speeds over 50mph. Is this correct?
I would like to know if anyone with a DFM disabler like Range, Carbyte etc has had a failure.
If there is a thread on this please link it as I would like to see the actual history of the failures.
viven44
Dallas, TX
All we know is that if/when the failure happens on a 21-24 built engine its catastrophic and isn't progressive
and
GM believes that the thicker oil will prevent this catastrophic event from happening
so, this whole oil debate is pointless, for your own safety just switch to 0W-40 on the 6.2L as GM has said that's the way to go on most if not all of the engines manufactured from 21-24 and still on the road... all the 0W-20 believers apparently know more than GM
mummer43
This thread has gone in a bunch of different directions but I will ask the question here rather than start a new one. Has GM issued an official remedy yet? Im taking my 24 Yukon in for service in on 5/23 and the service manager led me to believe that I will have to pay for the 0W40 oil unless there is an official remedy by then. Has anyone else had any communication with their service department or received any more definitive information?
blanchard7684
Senior Member
This is true!
I've been watching for this as well.
By my observation I have yet to see a failure from a category of what I'd call "enthusiasts".
People who change their own oil
Change it often
Use a dfm disabler
Defeat auto start/stop
blanchard7684
Senior Member
and
Vladimir's failure makes me think there is more failure modes than just the out of spec crank and rods. in other words, failure modes where infinite viscosity would not save the engine.
viven44
Dallas, TX
I'm not sure yet....
Vladimir thinks it couldn't be the oil viscosity because it happened so quickly... but that just how bearing failures occur..... it didn't help at all that he had the cruise control on, so the RPM was increased when it shouldn't have been
Looks like all those bearing clearances were suspect to begin with, and we know the bearing clearances increase as the engine ages, and all it takes is a singular event where the worst bearing was "breached" and that caused oil to heat up enough, and thin out further than it would normally, and the next worst bearing getting "breached", and so forth... all of this can happen quite suddenly as well if the oil heats up enough, mimicking an oil pump failure which I believe is what Vladimir thinks happened as he says "It seems to me for some reason, the oil pump abruptly stopped giving oil"
Stbentoak
And not only clearances, but surface finishes are a big issue also if they are out of Specification or too rough, they will start to work at each other much more quickly than if they are at or under what's desired. As I posted many posts ago there are many many factors that can lead into this, and the top two or three have already been discovered. Others come in to a much less extent, but ALL factors ball up to expose failure. Out of spec. parts, poor qualification of parts, insufficient testing and quality control at the factory and vendors.
Oil "can" be a factor, but not nearly as huge as once thought. The fact that replacement engines ship with 0W-20 lets you know that 40W is a band aid......
DuraYuk
This is true!
All this is, is a mis manufactured bearing inside the motor/potential debris. Thats it. The heavier oil is a band aid until the fix is implemented which means a new engine with the new part. Not all the Recalled vehicles will fail. But GM cannot pinpoint exactly which so they recalled the range of them.
The other 75 pages of this thread is nonsense being repeated over and over again.
That's it. End of story period.
23Seven
I should have mentioned that I still use jack stands after lifting with the air ride. I wouldn’t chance it either.
keg8605
Well found out about this recall via our 22 with the 6.2 dying on the highway last night. Pretty scary having a 3 month old and 3 other young kids in the car on a busy 5 lane Chicago highway.
GMCnewbee
Very scary and the worst fear of all of us. Can you give more details? How many miles, last oil change, were you able to coast safely to the side of the road? Everybody OK?
BacDoc
Vero Beach Florida
This is exactly why we are talking about this issue!
The inconvenience and cost of our $70-$100k trucks breaking down is one thing but the safety factor is biggest problem!!!!
Most of us buy these vehicles to haul loved ones and precious cargo.
So far the stories of failure have had no injuries or fatalities but statistics are not in our favor!
vcode
Indeed what I said as well. GM screwed up some critical engine parts. End of story.
jfoj
Because the majority of people that are performing oil analysis usually overly maintain their vehicles themselves and likely drive them in a way they will not likely dilute the oil as much. Also not everyone lives in areas where the a Winter temps are generally at or below freezing for much if the season.
jfoj
When did GM include a sensor to detect the presence of fuel in the oil? What is the name of the sensor and part number?
jfoj
@Vladimir2306
Has your 6.2l ever been opened up? Bearing replaced or other internal engine work performed?
Question about your trailer, looks like a twin jet ski trailer. Did you have 2 jet skis on the trailer when the failure occurred? Trying to get an idea of weight you were hauling. I also see a car top carrier and I assume you had the cargo area fairly full? Probably about 4,000 with trailer with 2 jetskia a with cargo and family members?
Conedaddy
