BREAKING: GM is officially recalling the L87
BacDoc
Vero Beach Florida
Vladimir, sorry to hear about that! At least you are alive and not injured !
I can see the situation where the motor dies at highway speed and the person behind you is not expecting a sudden drop in speed, all it takes is a few seconds. Even observant drivers will check the mirrors etc and have a couple seconds of distraction not expecting the vehicle in front to drop off speed without brake lights coming on.
What potential disaster is going to happen?
blanchard7684
Senior Member
Vlad's top concern was voiding GM warranty...
Something doesn't feel right about the fact that GM may void my warranty over the use of 5W-30 on my 5.3L.... it sounds like planned obsolescence....
I see grounds for some legal action to get GM's buy-in on 5W-30 or 0W-40 allowance across the board on 5.3L and 6.2L, following this recall.
This stuff is going down in front of us and don't feel good about sitting and doing nothing.
Anyone else?
I’m going with ac Delco dexos 5w30 on 4000 mile or less oci.
I’m documenting my oil changes with pictures.
The original design for this bearing was 5w30.
The design hasn’t changed. But the oil spec did.
Scarey
Obviously that oil dripping out of the filter is not normal. Do you have any way of getting a sample analyzed?
WalleyeMikeIII
Sunny and Snowy Minnesota
True that...but what is the oil spec design of the DFM stuff they bolted on? That is where the rubber meets the road a bit and maybe where the conflict..perhaps the DFM is what requires the 0W on the cold side? But, I truly agree...something is awry...and it is bugging me it is taking GM so long to make decisions on the 000 recall and associated instructions to the dealers and public...that document is conspicuously absent from public view right now.
D
DontTaseMeBro
Hello everyone, a week ago I talked about my 6.2 engine with a mileage of 75,000 miles. On which we cut the filter every maintenance and there were no chips, no metal, no wear products in it. And yesterday my engine stopped. The oil was fresh, the mileage was about 1000 miles. Driving was on the highway at 95 mph, the oil pressure was high. So it was a highway, then there could be no fuel in the oil. The engine lost momentum and the car shut down completely at 95 mph, I stopped on the side of the road. I took out the oil dipstick, the level was full, but the dipstick was so hot that I immediately got a burn through the napkin. I think the oil was 200 degrees C. In general, I will tell you everything in a separate entry when we open the engine. And now our masters are confused, because this has never happened before, my case greatly violates many existing hypotheses. And about the connecting rod liners too, if they were to blame, there would have been chips earlier, and they were not there 1000 miles ago. Everything happened so quickly, without a rumble.
Man that’s messed up. With the oil being so hot, wouldn’t the engine temp gauge have alerted you?
Vladimir2306
Behind me was my friend, who, like me, was riding with a trailer with a jet ski. So everything is fine
Vladimir2306
Sorry man that you had to go through this, yes please keep us posted on what you find. Did your vehicle set the P0016 code ?
No, there was no P00016 error moreover, my case is unusual in that often the chips allow you to drive another 5-7 thousand km
Vladimir2306
Wow @Vladimir2306, that is really bad. So sorry this happened to you. Looks like the inside of the oil filter is cooked, or is that metal sludge? Perhaps these rod liner's (bearings) fail catastrophically and very fast? That is the only part of your story consistent with the rest -- all is well until it is not well, then BOOM...no warning. Which, I believe, is the most dangerous part of this situation, as the user has no way to know if/when their engine may fail and they lose propulsion...
This is metal shavings and dust from the insides of the engine, which will soon be clear there, the engine is already being disassembled
blanchard7684
Senior Member
On a second look that could be cooked oil. Seen that in some industrial failures… in other words Dow stream of the bearing seizure.
GMCnewbee
Vlad, very sorry to hear about your engine. I have a 2022 Denali also. That picture on the right looks like there is water in the oil. Thanks for posting and let us know what you find in the tear down.
Vladimir2306
I will write a separate topic) there will be a lot of observations that break previous hypotheses))
ENTX
Sorry to hear about your engine Vladimir. Can you share more details on what exactly the car did when that happened: did it kinda completely lock up the engine/transmission (as if you slammed on the brakes) or was it more like switching into neutral and the car just coasted until the complete stop? The latter is bad but the former could potentially be absolutely catastrophic!
vcode
Yeah, 5W30 on dino oil. At least that is what my 2010 used. I can't imagine that is much better than 0W20 synthetic.
blanchard7684
Senior Member
It is full synthetic.
There is a small but good improvement especially on hths rating.
DenaliCountry
Sorry to hear of your issues. Mine didn't show any signs either prior to letting go. PITA all the way around.
Vladimir2306
Have fun reading))
Durobans
