Cryptothedog
- Joined
- Jan 24, 2021
- Posts
- 100
- Reaction score
- 95
Is there a way to figure out what your shift points should be changed to if you get larger tires?
To oversimplify, raise shift points up higher for taller tires.Is there a way to figure out what your shift points should be changed to if you get larger tires?
Yes there is. Are you using a tuner or software?Is there a way to figure out what your shift points should be changed to if you get larger tires?
I’m using a hypertech tuner. Tire size is LT275/70R18Yes there is. Are you using a tuner or software?
What size tires are you moving to?
