Battery Power Issue?
4wheelin
Land of Oz
I bought my 1999 Yukon a few months back and have fixed things here and there. It currently has a red top Optima battery, age unknown.
My rig runs around 13 volts when driving with or without just the front a/c on. At idle, with the a/c on, it will drop to about 11 until I start moving again.
Now, if I turn on both the front and rear a/c it drops to the top of the orange area, or about 9 volts at idle, and goes back up to around 13 volts while driving, but when I come to a stop it will drop back to 9 volts pretty much every time. If I leave off the front a/c and only turn on the rear a/c only it still drops to 9 volts at idle all of the time.
If I turn just the rear defrost on and no a/c it will drop down to 9 volts until I start moving again. I know the defroster cycles the a/c compressor.
I'm new to having a front and rear a/c. Is this normal? I think sitting at a stoplight with the battery gauge reading 9 volts is fairly low. Maybe not though. I just don't want to get stranded for something as simple as a battery or alternator. Before I go and have them tested I wanted to see what others know on this subject.
NathanJax
Vacation Nathan
Jax, Fl
Sounds like your alternator is going...
If you stop by any auto parts store, they can put a tester on it to see if it's a battery or an alternator problem for free.
4wheelin
4wheelin
Land of Oz
That's my suspicion. I think I'll stop by Autozone after work. Thanks for the response.
albac
