Bagged the rear..front coming soon...
thor1125
orange county
any update on the front yet? any more vids.. im looking to do the same set up on my 2004 was it difficult to install them in the rear? lookin good though..
afpj
Pardon my noobness, but where do bags go in the front? My 02 doesn't have any springs in the front. I finally understand the concept when it comes to the rears, but not seen anything for fronts without coil springs.
Happy New Year!
robb.
dallas
u puttin shockwaves in the front?.....
the issue i had with my shockwaves is ...the bad camber effect....when sittin at ride height....my tires would wear out quick...and the nut on my tierods would rub on the sway bar........in time the tierod nut became loose........also ...something about the air pressure in the shockwaves...a lil too much would bust the SEAL and u would have a small leak of air.,,,,
i finally took them off n went back to stock front......
fatnlowtahoe504
fatnlowtahoe504
New Orleans, LA / Hattiesburg, MS
was your front ride height below stock or did you ride with the front at factory height? cus if your ride with it lower ofcourse you would get negative camber and have ware but thats the first ive heard with that leaking and it rubbing the sway bar, did you get that shorter sway bar link as well for the front?
---------- Post added at 09:51 AM ---------- Previous post was at 09:46 AM ----------
pictures and videos should be up soon, i did the front and before i got to take it out to ride on, the exit valve(giggity) got stuck open some how so ive been waiting over a month for them to send me a new valve but i got the new valve in the other day finally and now i just need to find the time to put everything back on there and im going to do some install pics as well, sorry for the wait
---------- Post added at 09:55 AM ---------- Previous post was at 09:51 AM ----------
to fix the panhard problem, has anyone thought of doing a watts link setup in the rear???
i have def thought about it, i have to go look more into it to see how hard it would be to put on there
MOBmentality
Has a $25,000 Punch
I have heard the watts links leak bad.. you can do a triangulated 2 link.. from the rear frame to the pumpkin.. and ditch the panhard.. super cheap , easy, and effective since when paired with the stock setup it creates a 6 link..
or you can just do an adjustable panhard... and get away with it.. just tune it to your rim set.. an adj panhard doesnt become a bad thing until youre tucking ALOT and even moving a 1/4 inch one way or the other will kill you
fatnlowtahoe504
fatnlowtahoe504
the triangulated link seems to be the smartest move...i just need someone to come weld up some brackets for me to hold the link bars cus i have some 4 link bars that are sitting in my garage cus i cant sell them...
Conedaddy
