Backup light LEDs
UpAndDown
Boston, MA (MetroWest)
Hi guys I’m looking to replace my backup bulbs in my 07 Tahoe (bulb 7441 I think) with LED plug and play bulbs. I have read that the DieselLED style with the harness protruding from the back is the brightest option but I do not like how they don’t lock into the housing. I’m looking for a more factory style plug and play option. What brands produce the most/best light and last in terms of quality? Thank you for all responses.
U
UpAndDown
Thanks Gooffeyguy. Those aren’t the reverse lights for 07 though. Maybe I can see if they sell this bulb in the correct version. How is the light output compared to stock?
St. Louis
Oh, I thought the '07-'14 took the same reverse bulb size.
The light output is a lot brighter. My tail lights are smoke tinted and that's why I bought them, so they would still light up the area behind the truck when backing up and using the camera
EDIT: I believe the # 3157 are compatible with 7443, which I is the OE replacement bulb #
I started with some good strong LEDs in the regular backup lights sockets, and the increased backup light was still not enough. I also have an under dash switch on this circuit, so that I can use these lights as work lights in the evening of/when needed, such as evening setups at camp sites.
Durobans
