Howdy folks - this winter I had the above codes (B0100 & B0103) pop on my 04 Suburban LT. I have done some investigating and tried replacing the two front impact sensors with salvage units from the wrecking yard to no avail - I know that I have no way of testing them but they were free of any bulging/corrosion and they were extremely cheap so I figured it would be worth a try.
After no success with that route I started to trace wiring and examining what was easiest to access. I pulled the drivers seat to check the connections at the ABM and it would appear that I also have a leak somewhere and the excess moisture has sped up corrosion of the exterior of the box. There has been a small amount of standing water on the floor but the unit has not been submerged - moisture has just wicked up the carpet and underpad. I pulled the plug to see if any of the connections were damaged but they all look good.
Question is am I doomed to need a replacement ABM and reprogramming? Are these units robust enough to resist water intrusion? If I dry up the area and seal the leak (think it is most likely the windshield cowling/fresh air duct as it is on both sides) can I go back to looking at the rest of the wiring? How common is it that both impact sensors would trip fault codes relatively close together? I am not a parts cannon firing kind of guy - just want to exhaust all diagnostic routes before stumping for some pretty expensive parts.
