auto ride
dpmc84
how the hell can i disable the auto ride in my '04 tahoe 4x4! one idea is to delete it from the computer, any ideas? i want to lower my rig 2/3" and have normal shocks but this auto ride is holding me up! o ya and if it makes a difference already using arrnot/bilstein shock with a rear auto ride retard sensor in it. PLEASE HELP
puckhead
CO
I believe you can adjust and or cut it. Dont know for sure but I think some here have done lowering with autoride. Good luck on your search, tons of info here
THOLL223
Cut off the plugs that go onto the shock and wire up resistors. Remove the old shock, install new ones.
Then go under the hood to the fuse panel and pull the fuse marked RTD, that will disable the air ride, and fault lights will go away!
Max
Mile High
Denver
I don't think you need to wire up resistors if you pull the fuse, just yank the RTD fuse underhood and power cycle the battery a few times and it will be money.
BlizzardX23
Sacramento, California
Yes...pulling the fuse called "RTD" is how to bypass the air-ride
Step 1 - Disconnect your battery
Step 2 - Pull the RTD fuse
Step 3 - Reconnect your battery
Step 4 - Start truck and make sure no faults are displayed
^--- Thats how I did it without sending faults to my computer ---^
puckhead
CO
Blizz! Havent seen you in a while, good to see you back
Pachanga02
Ny
Will taking the fuse work on an 02 xl Denali and only changing the rear shocks? Thanks in advance.
Max
Mile High
Denver
Yes. The front shocks will still work just fine and the service ride control light won't pop up if you pull the fuse as stated. The compressor will stop turning on as well.
Pachanga02
Ny
Thanks Max I'll try it tomorrow hopefully it'll get rid of that annoying yellow message
trik
hey guys just wanted to know if anyone can help me out here..
Got a 2001 GMC DENALI and my auto air shocks are done... they are also electronically dampened will the Bilstiens mentioned by UVACARBUFF work for me as well... ??
Thanks in advance
DansOtter
North Carolina
Hey just wanted to say thanks for posting this fix. I know this thread was from a while ago, but it helped me out big time when my factory air compressor went out, and I kept getting the "Service Ride Control" message on my dash.
Anyway... thanks!!:winner_second_h4h:
