Following the spring weather shifts I've had some strange issues starting up with my Tahoe and no one thing is really matching with the other from what I could find so I figured I'd see if there's someone who's had similar issues or knowledge on what this could be
- every few days a cold start via remote start will fail, and that causes the entire infotainment system and memory seats to reset, occasionally also prompting a Service Theft Deterrent light on the dash which goes away after the next startup.
-the car can and has died in traffic, but I can't find the cause for it at all. It does seem to be linked to power draw in some form though, I've had it happen most commonly in turns.
-linked to the previous, it also freaks out at random when going above 2-3k rpm, dash flickering and throwing up random flags for all sorts of different components anywhere from Stabilitrak to the trailer brake harness, all of which go away after letting off the gas.
-usually following up these the car dies completely after being turned off, and as of the last couple days it has been happening every time I turn it off, whether it be a 5 minute or hour drive.
I replaced the battery in both remotes (assuming it was the theft deterrent system at first) and replaced the battery in the car itself (from an AGM to a flooded batt) which seemed to hold it fine for a month before the issues restarted once more.
Currently I'm at a loss, I've got a few things on my list to check into but for curiosities sake I figured I'd see if anyone had any insight. Only things I can think of currently are
-bad grounds on the car itself
-(my best guess) bad alternator
-fuses
-battery cable corrosion
-BCM
Anything helps ty!
-fuses
-BCM
Anything helps ty!
