ARH Headers Installed & Smaller SC Pulley
Superhoe
So finally I got around to installing my 1 7/8 ARH Long Tube headers and 3.25" SC pulley.
The headers fit amazing just like I expected coming from ARH. I still have a progressive meth kit from snow performance to install, but like the gains and drive ability of it now. I think I will let it be.
Here are the dyno graphs for before and after the headers & pulley.
Picked up almost 100 ft lbs down low and 60 hp.
Flywheel numbers should be around 516HP and 618 FT LBS. Not to shappy as the only mods are headers and the supercharger. The motor is all stock.
I am also running to factory exhaust still to keep it quite.
Might build a 6.2L for it and see if I can get 650/650 out of it. Already have the short block and heads.
Modded
That Guy
Damn that's some real power. For some reason I was under the impression it was a 6.2. If you get a 6.2 in you will be pushing at least 620.
Is there any work on the tranny?
Regency
650whp you want with the 6.2 build?
What tranny are you running?
What are all the mods?
Nice job btw I would definitley shoot for that 6.2 and get a tvs2300 on it with a meth kit and you'll be good for pushing those numbers...
Superhoe
Superhoe
Thanks,
No need to switch blowers. A twin screw is far more efficient and capable of more HP than the TVS rotors. This supercharger should max out in the 800 HP range. Also the manifold from Lysholm has a larger intercooler and flows better CFM of the Magnacharger.
I was looking for 650 HP to the tire.
---------- Post added at 08:27 PM ---------- Previous post was at 08:21 PM ----------
Thanks
No trans work yet. Just a really good trans tune. Talked with RPM who has built me several trans in the past and said that I should be good to 600's to the tire as long as the tune is good.
I have not done a stall yet. If anything I will do one to get the added benefits of strength and keep the stall tight. I built this as my daily. Will be building another toy again once I can figure out what I want.
Thanks for all the reply's.
THE YETI
Director of Operations
South FL
Lysholm twin screw > magnacharger tvs2300.
Good buy there!
---------- Post added at 10:29 PM ---------- Previous post was at 10:29 PM ----------
edit... are u running a 4L60? You're gonna blow that beast real soon.
Regency
Haha my bad still a performance noob
Superhoe
Superhoe
I am running the 6L80E. Its shifting great with no flares. You are right on the 4L60E they are a ticking time bomb on a stock setup.
OHSIXX
Milwaukee
Great build so far......nice numbers...I bet she sounds good too. That would be a nice DD for sure.
THE YETI
South FL
Ah, ok. That 6L80 is pretty stout. :)
JennaBear
Resident Ninja
San Diego, CA
Good buy there!
With the efficiency of the TVS now, I think you would be splitting hairs in saying the twin screw is superior.
As far as the 4L60e, never had any issues on my Tahoe running 11psi, never a hitch! But yes, they are a time bomb if you aren't treating them right.
---------- Post added at 01:36 PM ---------- Previous post was at 01:35 PM ----------
Good numbers! But I think they are slightly exaggerated due to the DynoJet factor.
Superhoe
Superhoe
DynoJet Factor??? I have owned this machine for 7 years now and have seen it actually read lower than Mustang, Superflow, Dyno Dynamics.
SAE is SAE.
JennaBear
Resident Ninja
San Diego, CA
SAE is SAE.
I assume that you have never heard of the DynoJet Factor, which applies before any SAE correction. The DynoJet factor is proprietary to DynoJet, and seems to vary depending on HP output level.
Here is a good show of correction factors being somewhat generous on the DynoJet:
http://g35driver.com/forums/engine-drivetrain-forced-induction/26743-mustang-vs-dynojet-good-read.html
Superhoe
Superhoe
Have heard this bs for years. Fact of the matter is with currant software from dynojet it will read generally lower and more accurate than other machines. My 1200 rwhp one mile drag corvette was the first to break 200mph in 06. We used to dyno at the altitude we would run at before racing on several diffrent brands. I always saw that the car read higher numbers on other brands than the dynojet.
I will agree to disagree.
---------- Post added at 09:19 PM ---------- Previous post was at 09:11 PM ----------
JKmotorsports
Austin, TX
Good looking numbers, sir.
I must not be treating mine right then:burnout: I'm on my 3rd LVL II 4l60e from Performabuilt, not including my stock trans. I had a Performabuilt in one of my 550hp camaros a few yrs ago and it held up perfect, which is why I went with them again. Guess it just isn't good enough for a 5500+lb truck. Going with a built 80 this time.
Superhoe
Superhoe
Thats what im saying.
You will love the 4L80. Did a conversion on a friends 07 Tahoe. It feels so great. Not sure why GM didnt just put it in the first place.
If you have not bought it yet a would highly recommend RPM Transmission. They have always treated me right and stand behind there work.
Thanks for all the comments on the Tahoe build. We kinda got side tracted for a bit. LOL
AdrienR
