Aircraft Landing lights Behind the Grill
Joeltz
Ok Making My LTZ mine, by adding Hidden Illegal lights behind my Grill.
All of my Chevys have had a pair of Narrow Spot minimum degree Air Craft lights!!!
When you remove the cover from grill to Radiator ….. The Grote .. brand name rubber housing light Buckets fit perfect without even drilling a Hole.
I Have the first one installed and the Aircraft Bulbs on the Way……. Just proving the install works…… And it DOES using Relay to feed 2 100 watt, 110,000 candle power….. Thats about a 20 AMP DRAW.
Cost for 2 Grote Par 36 mounts….. $40
2 Landing light bulbs….. 40
2 relays. ……. 20
14 gauge wire …. 20
1 toggle switch…… …………10
1 fuse holder ……… … 10
Not too hard just had to pull hood latch in 5 minutes, make spacers for mounts and run wires….
QUESTION for The group… where to drll thru or find grommet to use to bring wires for toggle. Mounting toggle Hidden down by hood release Handle
Joeltz
Joeltz
2 relays. ……. 20
14 gauge wire …. 20
Joeltz
Joeltz
Behind the Grill lights installed using Fog light switch to trigger the Bosch 25 amp Relays.
50 watt flood bulbs being replaced with 100 watt Aircraft Landing bulbs that pull 20 Amps
110,000 Candlepower with very Narrow beam degree angle.
Did not even have to drill a hole to Light Up
gat0r
DFW
you could use grommet under the brake reservoir , but there are a few items in the way on interior.
other option, i saw others use was grommet at front of passenger door.
gat0r
DFW
how hot do those bulbs get? would it cause issues w/ grill slats
how does beam look against wall? or down road?
bill1013
Air Force EMT/First Responder Firefighter
Waianae, Hawaii
Yeah, I wouldn't run them for long while you're standing still. They probably generate a lot of heat, so you might want to limit the amount of time they are on and only when driving. Also, mount them as far away from the grill as possible as the heat may warp/melt your grill. Of course if you have a metal grill the heat problem diminishes greatly. Aloha!
Joeltz
Joeltz
Pictures coming, these beams have a cat eye light pattern
Joeltz
Joeltz
Had “Aircraft Landing “ lights Behind the grill on my last few Trucks…..
They are for when you need them
This 215 Tahoe was easiest…..
No Holes drilled…. They are Par 36
The AVY had PAR 46
Joeltz
Joeltz
Got my Bulbez made in U S A
GE aircraft # 4509
Switching out the bulbs from my grote Advance auto tractor light
Par 36 for 19.00 ea.
Aircraft landing 4509s…. Both for $30
New uhhh - Bright ones just Using When the Time is Right…. & …. Bright
The Tahoe Yuks told me to look out for temperature
Past sizzlin’ spit….
Joeltz
Joeltz
GE aircraft # 4509
Joeltz
Joeltz
ALL Done you would not even know they were there
Unless I tap the fog light switch
No wiring thru firewall
got beam angle set to just above the flat line from factory projector beams
next pictures will be from 100 yards out in front
Xsbank
I see that those are incandescent. Unfortunately landing lights are only rated for 25 hours and they have a large current draw. They get hot but are air-cooled when used in an aircraft, I’m not sure if you can control the heat if your truck is stopped? The rad fan might be adequate? How did you find 12 volts? Usually they are 24, must be a source that I haven’t seen.
Without meaning to be annoying, I will likely be doing the same as you have done (good idea) but likely with a Rigid or Rigid clone so I won’t have heat issues nor have to do it again when incandescents fail.
There are led landing lights available but I bet they are spendy.
trailblazer
I did something similar with my Corolla. These are Hella 500 series housings ($50) and I installed Hella 130 watt bulbs in each ($12 pair). I wired them to activate automatically via relay when I trigger the high beam lamps. Insane brightness; I lit up an ELK with these on my way to work. These last way longer than 25 hours. The wiring is 12awg to 8” pigtails at the light housings. I crunched the math and the 14awg pigtails are adequate enough for the 11 amp draw per lamp.
26AT4
