Joeltz
- Joined
- Sep 28, 2020
- Posts
- 95
- Reaction score
- 74
Ok Making My LTZ mine, by adding Hidden Illegal lights behind my Grill.
All of my Chevys have had a pair of Narrow Spot minimum degree Air Craft lights!!!
When you remove the cover from grill to Radiator ….. The Grote .. brand name rubber housing light Buckets fit perfect without even drilling a Hole.
I Have the first one installed and the Aircraft Bulbs on the Way……. Just proving the install works…… And it DOES using Relay to feed 2 100 watt, 110,000 candle power….. Thats about a 20 AMP DRAW.
Cost for 2 Grote Par 36 mounts….. $40
2 Landing light bulbs….. 40
2 relays. ……. 20
14 gauge wire …. 20
1 toggle switch…… …………10
1 fuse holder ……… … 10
Not too hard just had to pull hood latch in 5 minutes, make spacers for mounts and run wires….
QUESTION for The group… where to drll thru or find grommet to use to bring wires for toggle. Mounting toggle Hidden down by hood release Handle
2 relays. ……. 20
14 gauge wire …. 20
