Aftermarket Stereo - "Modified Fit"
jmo2610
Hey I have an '04 Tahoe with Bose. I'm plan on replacing my factory head unit, probably with a touchscreen from Crutchfield. The description on Crutchfield says it will be a modified fit. Anyone know what that means exactly? Is it the rear brace behind the stereo? If so, is that a real issue removing/bending that brace?
Thanks.
J
jmo2610
Okay so it definitely means I have to cut out that rear brace, yes?
Harrison256
Does anyone have a photo of the rear brace cut out on an 03-06 (if it matters), couldn't find any via search.
Bigsteve04Ho
why remove the brace mine fits just fine - JVC KWAV70 BT
Sent From Your MOMS Bed
magicbus
Wichita Falls, TX
I've installed hundreds without removing anything more than some of the plastic at the back of the radio bucket.
tip: sometimes its also easier to remove the entire top dash pad to make sure no wires get hung up when the radio goes in.
Jdeshler
Alabama
Here's the cut
Here's the finish
Very easy, very worth it..
The opening needs to be filed out some too for the larger face of the double din
Harrison256
Thanks and woah thats weird, I actually went ahead and did it without the pics early yesterday but I did not have to cut that at all. I had a weird setup i guess where the only thing blocking it was some black plastics in the radio shell (two small black triangles on either side of and a little hump), I was able to keep the whole rear metal brace. I don't know if its because my tahoe is weird or my radio was small but I got to pull it out again later anyways so ill post pics for the curious
Edit: Ohh I see you have the 00-02 model looking at your AC controls, that slipped by me at first, makes sense now. Also your install definitely came out a lottt better than mine. Nice **
Dallinz
