98 2 door tahoe Tail light issue HELP PLZ!!
Chevy_John
Hello I have a 98 2 door tahoe and it’s recently developed an odd issue. The brake lights and blinkers work fine until you turn on either the running lights or headlights. As soon as you do I only get the left light working and the right has nothing. Any ideas on where to start? Anyone have access to a wiring diagram? Thanks
Big Mama
Virginia
Start with the easy stuff like your battery ground and cable. It causes all kinds of electrical problems especially where it grounds at the motor or chassis.
ivin74
05 NBS Nali
Htown, Texas
Try replacing the headlight switch. I would start there or disconnect the switch and run 12v to every wire to rule out the switch.
C
Chevy_John
Ok I’ll start there...Thanks. Is there anywhere I can access a diagram? I have plenty of test equipment but would like to know what I’m lookin at. Thanks
Big Mama
Virginia
I did a quick google search for 98 wiring diagram and several came up.
General Fodder
