73 Camaro
MrMonte
MrMonte
Fuel tank modded to use the 2011 Camaro fuel pump installed. 3" stainless steel exhaust installed up to where the cats are. Need to cut to fit, weld the c-ban clamps on.
Front nose/radiator support installed. Had to enlarge the opening for the bigger radiator. 2 large row crossflow radiator in & radiator hoses I bought fit. Will be installing the 2011 Camaro dual electric fans.
Most of the 2011 Camaro wiring harness has been installed. Folding rear seat from the 2015 ZL1 installed. Was able to install the ZL1 front seats using the 73 mounting locations by using brackets I made. Had headrest redone so no ZL1 logos now.
Pretty nice build, thus far!
MrMonte
MrMonte
After much tweaking the 2011 Camaro dual electric fans will fit in the 73 Camaro. The 2011 Camaro K&N cold air system will work too.
MrMonte
MrMonte
I didn't finish the 73 in time for this year's Hot Rod Power Tour so took my wife's 2014 SS Sedan (6.2L LS3 powered from factory) that we bought new & has over 150K miles on it. It was 7 week 12,000 mile roadtrip & had a blast.
73 Update: I did modify the 2011 Camaro windshield washer bottle to fit where I wanted it and got the cold air intake setup.
a1parrothead
