3 codes need HELP
992door
Greenville, NC
I have 3 codes that popped up. They are B0281, p0305, and p0507. Need help getting them fixed
SunlitComet
OBS Jedi-Do Good
unknown at this time.
please double check that b code don't see it listed.
It might actually be A B0281. means the ABS is not seeing the brake light switch acting properly as expected under given circumstances.
P0305 is the pcm counting a large number of misfires from cylinder #5
P0507 is Idle Control System High RPM. usually caused by:
  • An IAC valve which is stopped and cannot respond to the VCM.
  • A throttle stop screw which has been tampered with.
  • A damaged throttle or linkage.
If you need the details send me the email address that I can send you the charts .
992door
992door
Greenville, NC
Yea somehow I am getting oil on the #5 cylinder. Was told the compression on that cylinder was fine so don't know what it could be. I have not messed with any of the throttle stop screw and it idles fine sometime but other times it is a little high
SunlitComet
OBS Jedi-Do Good
remove valve cover, rocker arm and spring assembly remove seal install a new one and reverse procedure.
WARNING: if you do not have a method to keep the valve from falling into the cylinder don't do it.
992door
992door
Greenville, NC
From what I have looked most people make sure the cylinder is at the top and use an air compressor to put air in the cylinder
992door
992door
Greenville, NC
Ok i replaced the valve stem seals and it still is burning oil what could the be? Rimgs?
992door
992door
Greenville, NC
I will check again what is it suppose to be? It was not me that checked before
992door
992door
Greenville, NC
Got that fixed it was an intake manifold gasket. Now i have another problem one is stop lamp circuit and the other is i believe p0420
dizhai
