'22 YUKON Lifter & Cam Fail
YukonBDA
'22 YUKON SLT LIFTER & CAM FAILED 5.3L
Apparently this is common and a known issue due to the AFM/DFM system. Does anyone know what recourse I have with GMC? Are there any lawsuits? My warranty was 100k miles....at 111k miles my #6 cylinder lifter failed and it appears that the cam shaft is also damaged. Took it to dealer several times while under warranty with complaint of fuel smelling the cabin, knocking noise and other issues. All documented. They advised that it was likely my K&N cabin air filter. They did zero repair and I paid the diagnostic fee each time. Repair will be $10k...I can put a new reman engine in for $17k with a warranty. I'd prefer to get GM or the dealership to foot the bill, swap the vehicle or assist in some way if possible. Anyone have experience with this or recommendations?
LEsoftballdad
Suffolk County, NY
I am sorry you're dealing with this. I had the lifters fail on my 21 Sierra with the 5.3-liter engine at a whopping 1,700 miles, so mine was still under warranty. This is a well-known issue with engines containing DFM. I would not stop at the dealership level. If it's documented before the warranty was up, it sounds like they were trying to kick the can down the road until you were out of warranty.
mickheff73
How did this work out for you? I had a catastrophic engine failure in my 2022 Tahoe 5.3, Cylinder 1 Lifter fail, Cam fail, Cam scoring, Bent rod. 94k miles. Dealer said GM would pay 50% of $15k re-engine. Been a month so far, getting GM involved but not hearing much.
West 1
I have repaired many of the 5.3L engines with failed lifters. Some were at 100K and the most was at 200K. I have yet to find a damaged camshaft at tear down? As long as the owner shuts down after the engine starts running rough the cams are fine. If someone chose to keep driving 1000 miles after the failure they caused the cam failure.
Both shops and the dealership always assume worst case scenario. You have a tapping lifter. Replace the entire engine. They don’t want to tie up a bay, maybe have to wait for parts or a valve job. They always tell you it needs an entire engine.
Towmaster
