Yup you seem to understand. With fuel dilution and the extreme bearing loads due to high torque low RPM operation, the oil is just beaten into submission. The lower the RPM the more difficult it is to sustain an oil wedge, especially with thin engine oils. Causing frequent mixed and boundary layer lubrication conditions.
Add on the fact the oiling path in the V8's and probably other engines feed the main and rod bearings LAST. I would love to have an oil pressure transducer tied into the front main bearing oil supply on the V8 that can accurately track and log the oil pressure variations while under various condition. I would bet there would be all sorts of pressure variations due to the DFM system and variable cam timing requiring oil pressure and volume to operate at a high frequency leaving the main and rod bearings to suffer an early demise!
