2025 Tahoe 6.2-liter first oil change interval
stiedemann
With a new '25 tahoe with the 6.2, what is the recomended miles to do the first oil change? Dealer says 6000 miles, but I believe the first 500-800 miles is probably the worst on an engine since that is the break-in and when I suspect will have the most debris in the oil. I don't want to change the oil too early but also want to make sure I minimize damage to a new engine.
viven44
Dallas, TX
I'll probably be schooled for this... but I've just not bought into the debris theory a whole lot ever, after all there is an oil filter but :emotions33: break-in debris related damage makes a lot more sense if you are talking about break-in on small engines without filters (air compressors, and the like)... there can certainly be particulates that are smaller than the filter size mesh so it is probably a good thing to replace sooner than needed....we did ours at around 4000 miles on the 5.3....
Stbentoak
Since the first one is free, take it back at a convenient time around 2500 miles. I then change it myself in 5000-mile blocks. I know whenever I see 7500, 12,500 Etcetera roll around that it's time. Easy and if you're off a few hundred miles either way it's no big deal. Any earlier in that and you're really just wasting oil. It's been proven multiple times that the oil is good well beyond the time you think you should change it. Use a high-quality filter like AC Delco gold.....
PPK_
Oklahoma City
I did 500 miles on both my '24 5.3 and my '25 duramax. Duramax was clean.. 5.3 has a lot of debris in it. you can see... i would not wait.
Silverado4x4
I have never done early oil changes in new vehicles motors and I have had alot throughout the years unless it's a small motor without a oil filter. I always wait until the message pops up to change oil and back when vehicles didn't have OLM I did it at about 4-5000 miles.
GMCnewbee
Many opinions here and "feelings". Let's just say that an oil change never hurts. I think we did our first change at 3000 miles and then went to 5000 miles. That is what makes me feel good.
Antonm
I've been a gear head for a few decades and built several engines in my home garage (when you're an amateur drag racer, you break some engines). Anyway, I've always found the best practice to be a short interval first oil change (like 500 miles) on a new engine.
I'm sure GM does a better job at keeping things clean than I do during engine assembly, but it sure as hell can't hurt to do any early first oil change.
For my 23 Tahoe 6.2 I did a 500 mile oil change, and 3K mile oil change and a 6K mile oil change, then started sending oil samples for analysis. The oil sample results came back good BTW.
Marky Dissod
With a new '25 tahoe with the 6.2L, what is the recommended miles to do the first oil change?
Dealer says 6000 miles, but I believe the first 500-800 miles is probably the worst on an engine,
I'll never own a brand new vehicle - they're far too complex,
and almost none of that complexity makes them meaningfully superior to my '02 Z71.
But if I DID, I'd baby the engine and the transmission for the first 5000 miles.
Go ahead and change the oil too early, TWICE. Motor oil is SO MUCH cheaper than an engine.
Were I you, I'd even run premium for the first thousand miles for a gentler break-in.
Less of it winds up in the crankcase, and it has more upper cylinder lubricants than 87.
Antonm
While arguable if needed with a factory build engine as they are suppose to break them in on spintron type device, but babying a new engine is actually detrimental to it.
Reason being is you need to seat the piston rings before the cylinder walls glaze over and the only way to that is with cylinder pressure. So a few 3/4 throttle accelerations and varying RPM is recommended. Not saying to beat the hell out of it, but it needs some throttle input during break-in to get the rings seated correctly.
Marky Dissod
Wile arguable if needed with a factory build engine as they are suppose to break them in on a spintron type device,
If GM had broken in those L87s on a SpinTron,
then how'd they fail to notice how many hundreds of thousands of them made subpar?
If 14,000 owners hadn't complained, would they have done ANYTHING about it at all?
How many more thousands of complaints did it take before they extended the warranty on the ones that don't have P0016?
How many L87s are not going to make it to 175,000 miles? How many won't make it to 200,000?
... but babying a new engine is actually detrimental to it.
Reason being is you need to seat the piston rings before the cylinder walls glaze over, and the only way to that is with cylinder pressure.
So a few 3/4 throttle accelerations and varying RpM is recommended.
I don't disagree with this; in fact I'd not use Cruise Control on level ground for the first 5000 miles.
But is a vehicle that weighs at least 5000lb ever truly babying the engine?
The way I drive, despite being far tamer than ever in my life, is far from gentle.
My point was and still is that I strongly doubt GM actually does enough break-in (if any at all).
Antonm
Yeah, you'd think they would've noticed the AMP draw on the driving electric motor being a little high or high a vibration at turning speed (its typical for a spintron to also have vibration accelerometers).
IDK how they missed it ,,, but I'd bet they know by now exactly where, when and how they f-ed up and there is probably a pretty hilarious inter-company memo going around about it.
Marky Dissod
IDK how they missed it ... but I'd bet they know by now exactly where, when and how they f-ed up ...
GM likely spent the absolute minimum possible to build it / initially inspect it,
and are now spending the minimum possible to 'fix' the problem.
Note how they're making L87 owners switch to 0W40 -
GM is literally transferring some of the ADDITIONAL cost of maintaining GM's mistakes to the customer,
instead of fixing / replacing it.
I'd've been more impressed if they'd extended the suspect-L87 warranty to 12 years /180,000 miles.
That'd've been impressive.
On the other hand, despite how many part numbers L87s share with LT1s, it's astonishing
how many L87 owners don't see how the similarities and insist on the differences.
... and there is probably a pretty hilarious inter-company memo going around about it.
By the time the general public learns of this info, they won't be able to apply any of the lessons ...
j91z28d1
changing old sooner than later never hurts anything. please do it yourself and buy a filter cutter and inspect it.
on my engines I've built, first oil change of the break in oil after a warm up cycle or 2. and then at 500 miles or so and inspect the filter.
I've only brought 2 new vehicles personally. one was my bike, rode it home from the dealer and changed oil, then broke it in. my ls1 car I put about 75 miles on it, changed oil and it made it's first pass at the 1/4 mile at 250 miles.. engine never gave me a hint of trouble at over 100k when it was stolen. I believe it would still be running good today if I had it
if you care about the engine currently in your truck, I'd change oil, and I would personally go 10w40 not the 0w40 unless it's sub zero starting Temps where you are right now.
cut the filter open and inspect it closely as well, if clean you're good, if you find much of anything, change it again in a 1000 miles and inspect the filter media again. if clean, you're probably good. if you still got metal, try to get a new engine from gm, yours is probably already hurt.
schmit55
Dont people say something about using 100% gasoline and no ethanol mix at first on a new L87?
mickier
.....CHANGE IT....
Did mine at 800mi. Even if it does nothing real, I'm convinced it will help... ALSO - always use synthetic and always change it before the computer hits 30% remaining (or better)... I can't always remember on my own, so I rely on the computer and usually do it by around 40% remaining. (hey I do it myself and it's $50 bucks)
ZKWBQD
When I get a new vehicle, I change the oil at 500 miles and then every 3000 miles thereafter. This may not be legal in California.
Marky Dissod
Lake Speed Jr did a video about the differences between 87 & 91.
If I'm ever lucky enough to own a brand new engine, it gets 91 or 93 for the first 5000 miles.
Gearz
Oil is cheap so change it at 500-800 then do it again at 1k. Better safe than sorry. You would be surprised on how much debris comes out in the break in stage.
2024 White Tahoe
So the oil filter doesn’t catch the debris you have referenced?
Durobans
