2023 Yukon Denali Side camera - intermittent issues
Swaz07
Anyone seen this one? Right side camera intermitantly fails. No rhyme or reason. 20% failure rate. Dealer says it did not fail when I brought it in so they can't investigate.
Does anyone have a wireing diagram showing the connection locations between the camera and the Infotainment unit?
My money is on loose connector.
Ibustbravo
Centennial, Co
Get an alldata subscription or Identifix.. I also have a GM Techline subscription. I have been updating all the firmware in the 20 some modules my 15 Yukon this week. I've fixed the camera flicker and a bunch of other ghost problems. Hoping my lift gate window will magically start working again. It's been on strike for a few years.
It's kinda like having insider info. I know for a fact someone else is going to charge you min $250 to plug their diag gear into your truck. It's worth the investment.
C
Vladimir2306
I had the same thing a couple of times, in the Yukon 2022. took place immediately after restarting the car. I chalked it up to some kind of bug.
from the same series, when several times the windshield wiper blades froze for 1-2 seconds, and then worked normally again)
Critter0382
