2022 6.2L Yukon Spun Crankshaft Bearing
clojczyc
Hi all,
About 3 weeks ago I had my Yukon with the 6.2L engine in cruise at 115km/hr (~70mph) when all of a sudden I realized I was dropping speed and noticed the vehicle was in neutral and the engine was off. No unusual engine noise occurred or check engine lights came on. I coasted to the side of the highway and came to a stop. When trying to restart the vehicle nothing would happen. I ended up having the vehicle towed to my local dealership where they tore into the engine and found that the crankshaft bearing had spun. Vehicle was purchased in December of 2022 and had roughly 5000km on it when the failure occurred. Anyways, the dealership is going to attempt to repair the failed parts.
slupie
Bartlett, IL
If it spun a crank bearing there is possibility of metal debris in the engine. Like @tom3 said get them to replace the engine with a long block. Do not take it back with the original engine rebuilt by the dealer.
Blackcar
A spun bearing on main bearing in new truck definitely demand new engine, there is something going on with 6.2 engine the forum is seeing a lot of them reported here recently.
B-train
Agreed. Don't accept anything less than a new motor. Or......have them rebuild it with an AFM delete.....that would be a slick deal
DuraYuk
AFM has nothing to do with a spun bearing lol.
It's the most misunderstood thing around here haha. Beating a dead horse smh.
Blackcar
Soo, if it's so misunderstood why isn't explained. This is reason for everyone participating here's concern.
B-train
Mr. Goodwrench, that wasn't my point at all. I'm very well versed on what causes a spun bearing. AFM is a constant thread around here, as is some sort of deleting or disabling it. So I figured I'd put a line in that guy's on here would agree with and find entertaining, however unrealistic it may be to have done under 'warranty.' It's a thing called a "joke" to make some light of a ****** situation.
DuraYuk
I see. It was your attempt at humor. Haha.
tom3
For an engine with this mileage I'd sure assume it was not an assembly screwup, bearing failure, oiling problem, or a machining deal. I'm guessing it was a casting shift, several heat cycles and the block distorted a couple thousands of an inch. Rebuilding the motor won't guarantee it's done with the movement. But that's just a guess. Keep us posted, inquiring minds are real nosy.
Boomer73
Boom Boom
Crownsville, MD
Hi all,
Welcome to the L87 spun crank bearing club. I have two spun crank bearings and am waiting on a new engine (indefinitely according to GMC).
vcode
That indefinitely part is disturbing, especially for the coin paid to get the 6.2L......
Hey please see my post - I went through this exact scenario. I’m about a week in on my new motor now. Dealer had my car for a month waiting on a new 6.2L. Tried to share relevant details in my posts but feel free to reach out if I can help.
Hi all,
I’m curious of your exact mileage - My rod bearings blew at 3,677 miles. (Cylinders 5 & 6) . Can’t just be a strange coincidence here.
I did the miles / KM conversion and you’re at around 3,106?
FYI, my starter motor was toast and also blew a 400A fuse from the handful of times I tried to get it to turn over before it was towed to the dealer. This was only discovered after they had installed the new motor.
C
clojczyc
My failure were the rod bearings on cylinder 7 which occurred at 5568km (3460 miles) on the engine.
RST Dana
EMT/First Responder Firefighter Supporting Member
OH
Your starter was toast because it tried to spin a locked up crankshaft? That would be correct.
Pretty damn close … I wonder what GM’s thoughts are on these motors spinning rod bearings between 3-4K miles. There’s gotta be a short list of these somewhere in their system.
Sucks for us. Hope they get you back in order soon.
Hodmjstone
