2017 Yukon xl ticks every second
Gmfm
50k on the clock. I seen a post in the past with someone with what sounded like a similar problem, but couldn’t find it in the search so here we go.
2017 Yukon xl it makes a ticking noise in 1second intervals and with a stethoscope my best guess was around the bell housing. I have a link to the video if anyone has any input on what it could be.
Big Mama
Virginia
Well ticking isn’t normal ticking usually comes from a lifter a sticky valve or vacuum. Is the sound obvious from any angle? Not just by your belts as in a bearing on your alternator or idler pulley?
It's the Death Clock ticking away for the torque converter ...or A/C condenser ...or valve train ...or transmission ...or shocks/struts ...or door pillar trim clips ...or infotainment integrity ...or liftgate actuator...
You'd think that, with such a premium vehicle, GM would have at least used a digital Death Clock. I guess even that was another cut corner.
Big Mama
Virginia
On mine the death clock is the engine hours in DIC it counts backwards
Michigan, Metro Detroit
Any updates ? did you figure out the cause of this sound yet ?
kchaga1978
