2017 Hoe LT Premier
Flowers25
Enjoy reading all of the threads. Just bought a 2017 hoe with 90K miles. Anything I should check into to make sure I’m going to get the life out of it?
I’ve drained the moisture out of the left headlight casing and resealed. Changed out some covers, etc.
Just got the rear turn signal error followed by the rapid flash. Plan to change out the bulb.
What am I missing?
What am I missing?
SpyShops212
Your best bet is try to buy a new used one OEM that way it will match the other side. Once it gets moisture it will be hard to make good again unless you have experience.
Brian71
Guelph Ontario
I would replace the transmission fluid and filter. I purchased mine in 2021 with 60,000 miles. It now has 120,000 miles. In that time I’ve replaced the fluid/filter twice.
Other than that it’s been mostly wear items, nothing major
RST Dana
EMT/First Responder Firefighter Supporting Member
OH
If it has not been replaced, your AC condenser WILL fail/leak and the repair bill at a dealer is a tad over $1k. Or you can just keep your windows down all summer.
RST Dana
OH
I was referring to your post on problem with condenser.
It’s only applicable if the problem vehicle is under the miles or months. The op has a vehicle that has too many miles and months.
F
Flowers25
Update: I ended up removing the headlight, draining the water and resealing. I’ve added some husky floormats. I have noticed a sluggish crank/start. Assuming maybe battery. Anyone else have similar issues?
scottd
