2016 Tahoe..New poster to the forum
Gretchen Brown
Hello All;
I have been a member since 2017, and have lurked, reading all of your posts. I checked for this problem and haven't found anything like it.
When I depress the Brake pedal, in the morning, before I start my 2016 Chevy Tahoe, SOMETIMES, not always, there is a loud high pitched squeal.
I haven't turned the Truck on, it isn't moving. Is this part of the recall, or could it be something else?
Regards,
Gretchen
PG01
Up here to the right
Where does the noise sound like its coming from?
Inside, underneath, under the hood etc.
Have someone step on the brake to recreate the sound and try to pinpoint where you hear it loudest. that would be helpful in giving you a more definitive answer.
Gretchen Brown
Gretchen Brown
Thanks for answering, Galante.
To me it sounds like it is coming from under the steering column, in the inside of the truck. It doesn't happen all the time, and it doesn't happen (yet) when the truck has been driven during the day.
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
First: Welcome to the forum from Oregon, Gretchen
We recommend that you put all your rig(s) info in your signature so we all don’t have to guess at year, make, model, engine size, trans, rear axle locker…….etc. Makes it way easier on all members that attempt to help, to have that info right up front. It is also recommended that you take a pic of your RPO codes, on the inside cover of the glove box, and post that image in your signature. All this info will greatly help those that will try to help with a problem.
If there is any other info, like upgrades, mods or recent mechanical/maintenance work done, that would be helpful in any post as well. Too many times a question is asked by the poster and after about 10 responses we find out that the poster has done recent work to attempt to fix the problem or work that was done that SEEMS not related to the problem.
PG01
Gretchen, is the noise like a squeak...metal on metal or more like a vacuum cleaner squeal like belt is stuck or slipping?
gat0r
DFW
cant say i've read about anyone reporting that noise
how loud is it? can you possibly get a cel phone vid of it?
wonder if some wd40 or white lithium spray could help?
gat0r
DFW
there is a TSB for brake booster, unsure if there are noises mentioned related to it
spray some wd-40 or some type of graphite lubricant on the mechanism down there, the brake pedal is metal and there is a hinge spray it there.
Gretchen Brown
Gretchen Brown
Doesn't sound like a metal on metal. It occurs when I press the brake pedal. The noise stays the same pitch and volume and then stops. More like a belt squeal.
Gretchen Brown
Gretchen Brown
Thanks, Doubeleive, I can try that, but I wonder why it is so inconsistent.
Gretchen Brown
Gretchen Brown
Thank you gat0r; It's inconsistent, but I can try...it doesn't happen every time tap the breke.
No work has been done recently. The last work was a nail in a tire, which was fixed.
Gretchen
OR VietVet
Willamette Valley
Sure sounds like it has to be booster related. When the Tahoe is running do the brake pedal and foot pressures feel like normal? Does the pedal feel harder than normal when applied?
OR VietVet
Willamette Valley
I saw the TSB, I was wondering if it is related. I guess, I will brave the dealer:)
Good luck with the dealer because normally if they cannot duplicate the noise/problem, they give up very quickly. Unless the TSB states anything about intermittent problems.
Gretchen Brown
Gretchen Brown
Thank you for the proper protocol PNW VietVet. I will do as you suggested....I have done nothing to the truck, it is pure stock, except put new tires on it. Regards.
Sure sounds like it has to be booster related. When the Tahoe is running do the brake pedal and foot pressures feel like normal? Does the pedal feel harder than normal when applied?[/QUOTE
Brake pressure and pedal feel about normal. But, I haven't been doing a lot of driving recently with the shelter in place orders:)
well if you look under there there is a rod that connects to the brake pedal and it enters a rubber bellows for the master cylinder, look right there and see if looks dry the rod rubbing on the boot could be making noise, mine has some light grease right there, mine also makes a air sound if I pump the brakes without the engine running until builds up pressure then it's sort of a squishy noise.
Gretchen Brown
Gretchen Brown
does it sound like this?
Thank you for the research gat0r. No, that squeak doesn't sound like it. The squeak is too short and is consistent. Mine only happens upon depressing the pedal, its about 2-3 seconds long and then stops. No noise upon release of the pedal.
TallHoe 96 OBS
