2015 'Burban Oil Leak
hoserama
Houston, TX
I have brought my 2015 into the dealer I purchased it from three times for a engine oil leak. Oil collects on the oil pan cover and drips onto my drive way. Each time I bring it in the dealer looks it over and tells me it's residual oil and have cleaned it up.
I have read on here regarding some customers reporting oil pan leaks which I suspect is my problem yet I am getting nowhere with the dealer.
Has anyone been in a similar situation that can make some suggestions?
hosseface
I had an oil filter leaking on my 15. Switched to K&N and it solved it.
Trying to get anything accomplished at a dealer is going to be a workout. Honestly, I view warranties as worthless because its next to impossible to get anything fixed.
YOU are going to have to do the leg work. Get it SPOTLESSLY clean with some brake parts cleaner, drive it for a couple of days and keep an eye till you find where the leak is coming from. Then, good luck getting them to fix it.
H
hoserama
Houston, TX
Problem solved.
Ended up being a transmission oil line. Was covered under warranty of course.
I wouldn't expect this on a vehicle with 30k miles.
