2013 Escalade ESV P0131 and P0171
skpyle
Senior Member
Hello Gentlemen,
Well, the honeymoon is over with my 2013 Escalade ESV Premium. Last night, the check engine light came on. This morning, coming out of work, the remote start didn't work. :(
Once home, I dug out my neanderthal scanners and pulled codes. I have the following DTC's stored:
P0131 (scanner called it 'O2 sensor circuit low voltage bank 1 sensor 1') Alldata calls it 'HO2S Circuit Low Voltage Bank 1 Sensor 1'
P0171 (scanner called it ' System too lean bank 1') Alldata calls it 'Fuel Trim System Lean Bank 1'
NOTE: I did not 'feel' the check engine light come on. I just happened to look down and see it on. The vehicle drove fine (no different than my limited 5 days of driving) last night and this morning.
Also, this Escalade is a Flex-Fuel model.
I have done some quickie google-fu and general consensus is:
P0131 is likely a failing bank 1 primary O2 sensor
P0171 is likely an air leak.
However...according to Alldata, conditions for setting P0171 include P0131 NOT being set. Meaning two different issues? I had been caught in the 'chicken or egg' mentality. Meaning, was I seeing codes for a failing O2 sensor, or is the O2 sensor reacting properly to an air leak?
I used both scanners to pull some live data at idle. NOTE: I have a clone Tech 2 on order, but it likely won't be here for another week.
FRP(psi) 43.1-43.9
ST FTRM1(%) -0.8 to -2.3
LT FTRM1 (%) 2.3
ST FTRM2 (%) -1.6 to 0.0
LT FTRM2 (%) 2.3
O2S11 (V) 0.100 to 0.750
O2S12 (V) 0.645 to 0.670
Looking at Alldata:
P0131 is set when the HO2S voltage drops below 0.050V. Looking at what I believe are my primary O2 sensors, neither is below 0.100V. However, note how sensor 1 varies while sensor 2 is relatively steady.
P0171 is set when the long fuel trim for bank 1 is greater or less than a calibrated value. I sorta got lost looking at that one. I did note that both long fuel trims were stable at 2.3%. However, short term fuel trim 1 was acting rich(?) while short term fuel trim 2 was acting a little less rich(?) Rich meaning negative value is the ECM pulling fuel.
I have searched the 2007-2014 forum, did not really find much for both P0131 and P0171. Hence my post.
I am writing to see if anyone has any insight?
I am on a crunch because I should have been in bed hours ago. To get up this afternoon to go to work. I have to go to work tonight, and Sunday night. Monday morning, I am off for a week.
My intent right now is this:
-tonight, clear the codes before I drive to work. See what happens.
-Monday and Tuesday, perform the transmission work I had scheduled, because I will be replacing both primary O2 sensors with GM Genuine 2133866 units as part of it. After the transmission adapts are relearned, I will see how the Escalade drives on the way home, and see if the P0131 and P0171 return.
And troubleshoot accordingly.
Thanks for listening!
P.S. I learned in the owner's manual that the remote start will not function if the check engine light is on. Good to know...
Hello Gentlemen,
FRP(psi) 43.1-43.9
LT FTRM1 (%) 2.3
LT FTRM2 (%) 2.3
Looking at Alldata:
Solve for 131 first, it likely caused the other. With the Key on, that sensor should read about 450mv. You can also measure resistance in OHMs on that particular sensor.
Swap upstream sensors. If the problem moves, it's time for a new O2 sensor. If it does not, a mouse is eating your wires or your ECM is bad.
skpyle
skpyle
Senior Member
That makes sense, and dovetails with what I was wondering.
I have modified my plan slightly, I am going to connect the scanner and (safely) watch the HO2S bank 1 sensor voltage as I drive to work tonight.
I have two new sensors, So I am just going to replace them. I will check the voltage and return pins on the sensor plugs at the time.
Thanks! I very much appreciate your advice.
skpyle
skpyle
Senior Member
While driving steady state on the highway to work, I was able to sneak peaks at the scanner.
O2S11 varied from 0.000 to 0.750V
O2S12 was steady from 0.735 to 0.740V
This tells me that bank 1 primary O2 sensor is going flaky. It will be replaced.
It's supposed to vary once heated up but that is not the only tell all if it has gone bad.
I miss the smells, paint, DMF, JP5, salt air. Spruances, Kidds, Ticos, Arleigh Burkes?
skpyle
skpyle
Senior Member
Good point.
Depends upon the day. The longer I’ve been out, the better it was…
Tico class, though trained on the Spru-cans.
wsteele
The upstream sensors (sensor 1 on both banks) is supposed to switch up and down in voltage when operating properly. If it isn't switching (relatively flat line on the graph), the sensor is bad. The downstream sensors (post cat, sensor 2) will look more like a flat line as they are reporting your cats are working.
Since you are going to swap them with new, you likely will get a pretty good idea if you have one or two problems.
skpyle
skpyle
Senior Member
skpyle
skpyle
Senior Member
Makes sense, thanks!
skpyle
skpyle
Senior Member
Alright, this issue has been resolved.
This weekend, my wife’s aunt (I’ll explain who she is and why she matters in my general discussion thread) contacted the service manager for the nearest Hendrick Cadillac dealership, in Monroe NC. She got him to squeeze me in for Monday, October 18th, as soon as I could get there.
I got off work Monday morning at 7:30AM in Spartanburg SC and cannonballed up to Monroe NC. There were a couple of misadventures along the way, but I got there at 10:15AM.
Oh yeah, forgot to mention, 20 minutes into the drive, the check engine light went out…:mad:
The Service tech had my Escalade at 10:30 and got to work.
The tech confirmed the codes had been stored, but were not active. He looked at the data from HO2S bank 1 upstream, it looked stable. He recommended replacement of the sensor.
And here is where it all went wrong…
I had two new GM 213-3866 heated O2 sensors onhand. They could not use my parts due to policy. OK, whatever.
Then, the kick in the nuts. None of this was under warranty. I had read the warranty the previous night at work. However, I missed the significance of the wording in the ‘engine section’. The warranty only covers engine hard parts. Sensors and such are not covered.
Soooo…I paid $482.36 for the privilege of driving almost 4 hours both ways, having been up since 4:00PM the previous day, then having a Cadillac dealership Service department diagnose and replace the HO2S bank 1 upstream sensor that I had planned on replacing later this week. They installed a GM 12583804 HO2S.
I am stupid.
Most of you are now saying, “you shoulda‘ just left.” My wife pretty much cursed me out in saying that.
You are correct. However, I was still on the hook for the $100 diagnostic fee.
More importantly, my wife’s aunt went out on a limb and shook down the service manager on a Saturday afternoon to get me into the Service Department on Monday morning. I didn’t want to look like an a$$hole and cause flak that would get her in trouble. Make sense? That’s OK, it doesn’t have to…
So, the check engine light has stayed off, so I am saying it is good now.
Onto the next adventure!
Also, I replaced the HO2S bank 2 upstream sensor when I dropped the exhaust for the transmission work.
mikeyss
Longmont, Colorado.
I wonder how many other customers had to be pushed out if the way for yours to come in for something you, as well as others, told you was the issue.
skpyle
skpyle
Senior Member
True enough. However...I thought it would be a warranty issue. I accept blame for this one.
Besides, I got my just comupance for this at the transmission shop yesterday.
curbud
