2012 Tahoe Z71 - 6L80 Transmission
ecordell
CordellDesigns.com
Merica
I just purchased my Tahoe 3 weeks ago (3/10/18). Everything seemed fine with the vehicle and we made the purchase. Three weeks later (3/31/18) the Tahoe quits moving and makes a terrible noise as if you are shaking around a can of nuts and bolts. It now sits at my mechanics shop and needs a transmission rebuild.
The problem with these transmissions (2008 - 2016 6L80) have this issue. There is a drum inside the transmission that has a weld on it that ends up cracking, which in turn affects the pump (I don't know what I'm talking about, just reiterating in broken English what I was told) and eventually transmission failure. GM knows about this issue and has done nothing to this point. The issue typically comes in around 100k ish miles. There are no aftermarket upgrades or newer versions. You simply have to use the parts from GM to rebuild the trans and that's it (which might last another 100k).
Oh btw, this is a $2400 - $2500 repair
Pretty sure I just got ****** on this Tahoe purchase!
General Stalin
Never heard of this issue you speak of. As far as I know the 6L80 is a robust and reliable transmission so long as you aren't trying to push it beyond it's capabilities. I've got a 2007 Denali with the same 6L80 in it that it rolled out of the factory with; it's got nearly 200k miles on it and I've done literally nothing to it. I haven't even replaced the fluid or filter....
The only problem I've ever had transmission related was the bushing that attached the shifter linkage onto the shifter lever on the side of the tranny rotted out so I replaced with with a rubber grommet I bought at Ace hardware.
Sorry you bought a lemon though :\
that part is called a torque converter and yes that is the part that fails and takes the pump with it, yes it is a known issue. you can have a better more reliable converter put in when they do the repair so that it might possibly last longer next time around.
ecordell
ecordell
CordellDesigns.com
Merica
The drum I'm talking about is 1 of the two drums inside the transmission that contain the clutches. I know what the torque converter is lol.
The stealership decided that they would basically pay half (a little more) and gave me $1600 towards the rebuild of the transmission. Guess I should consider myself lucky on that. I'm starting to wonder if I should get a better trans cooler for the tahoe (the 6l80 is a high heat generator)....
I put a flex a lite on mine and a B&M trans pan, the flex a lite was very to install, just disconnected the stock one and drilled to new mounting holes for the flex a lite and bam it was done, I could go with a even bigger one easily
the local big wig transmission shop here told me the most common thing with these 6l80 is the torque converter going out and taking the pump with it, otherwise there pretty good.
ecordell
ecordell
CordellDesigns.com
Merica
I did ask him about that. He did say that is also a possibility and that the only way to tell for sure what happened was to rebuild it (with upgraded parts). The trans still hasn't been dropped because I was fighting with the dealership to fix it. He starts on it the first of next week.
I'm gonna stop in there and talk to him and see if he thinks adding a bigger trans cooler and upgrading the torque converter should be done. Mind you this is my wifes vehicle and it's just a "take the kids to school, go to work, light traveling" vehicle.
Buzzcut
Fwd clutch drum. Common issue on 4l60 e. Guess gm didn’t fix this.
raidernationmike
Redondo Beach, CA
my 2009 Yukon Denali was having hesitation issues in stop/go traffic and having a hard time downshifting back into first gear. Normal and high speed, no issues. But with LA stop/go I'd have situations where it would not go back into first and in a full stop i was starting my acceleration in 2nd gear. If i shut off the ignition and open the door and then start the engine back up, it would go back to normal and into 1st gear. it's over 150k now and i decided for a full rebuild ($3500 incl labor). Sucks!
raidernationmike
Redondo Beach, CA
Same issues: tech module issues, drum/weld point crack, How many miles on your Tahoe?
ecordell
ecordell
CordellDesigns.com
Merica
126k on the clock. Talked to the guy last week and confirmed the weld point blew apart and got into the back of the pump and chewed it up. $2600 rebuild :(
raidernationmike
Redondo Beach, CA
bummers. out here in CA labor costs are higher so my full rebuild is $3400. they could’ve just repaired a few items and it would’ve cost me sub 2000 but at that point i went with a full rebuild
ecordell
ecordell
CordellDesigns.com
Merica
Yea the bad part, Chevy know about this problem and just ignores it. There is a company out there working on making a better design, mainly out of different material without a weld. I thought really how hard could it be to have one turned from billet aluminum and 1 solid piece?
Meccanoble
Georgia
I always wonder how the boosted guys do with these trannies. I was hoping the tranny off a different truck would be more durable but sounds like they are all the same.
ecordell
ecordell
CordellDesigns.com
Merica
They were used from late 09 up through 15 or 16. Heat is the big problem with these trannies, keep the heat away and pray. It’s a know bad part from GM, no good fix known, just a bandaid for another 100k
schafer98
