2012 Tahoe after market amp hook up
Jnewkz
I gotta 2012 Chevy Tahoe lt with stock head unit. I just got a 1000.1 kicker amp running a kicker 12. I was wondering how I would hook the RCAs from the amp to the stock head unit, or I needed a hi lo converter or whatever. Please let me know ASAP thanks
shundal
NorCal
your going to need a line out convertor at the least to get the signal to your amps. you can use a simple one like the Scosche LOC80-2 which will get you a low level signal to your amps or you if you want a stronger signal and more adjustment, you can go with an Audiocontrol LC2i.
The Schoche is under $20 and the Audiocontrol is around $100
J
Jnewkz
Thanks. Can you find the scosche in stores or only on the Internet?
shundal
NorCal
Your local stereo shop or best but should have it. I'm pretty sure i've seen it at walmart before too.
Mohq
