2007 Yukon Denali Fuel Pump Access Door
Fixxer
Hello,
I just got done installing a fuel pump in a 07 Denali. I decided to cut an access hole instead of dropping the full tank. I thought I would share my measurements and photos with you in hopes that it might help someone else who wants to do the same.
Drill out all of the spot welds inside where your cut is going to be. You'll notice that there is some heavier structure towards the back and right sides of the hole. The object of this exercise is to cut just enough of that structure to get your pump out while leaving as much as possible to support your door.
I trimmed out the back structure a little too much. The next time, i will leave a little more of a lip to screw the door down. Save the piece that you cut out- well be using it later.
The floor piece that i cut out
Measurements
I used that piece that i cut out earlier to support the lower left part of the door. I drilled and tapped it with some M6-M10 bolts. Be extra careful when cutting in this area because there is only an inch of clearance to the tank. When i was drilling the bolt holes, i put a piece of metal underneath to keep the drill from going too far and damaging the tank.
Out with the old and in with the new. Be careful not to spill gas everywhere. The sender has one or two quarts of gas in it when you pull it out.
Access back in with black RTV for sealant. I added another piece of metal under the left side for extra support, and simply drilled and tapped in the m6-m16 bolts. The bolts with stars are holding the support for the door, that's why i added the note.
So there you go. I used a swazall to make the cut. Like i said, just take your time and keep your blade depth to a minimum. Be extra careful on the front drivers side of the hole as there is only an inch of clearance under your cut. I hope this helps someone who wants to be able to change their fuel pump easily in the future. I hope to make more of these in the future. I will share my measurements with you ;)
Wolfbraid
Winston Salem, NC
One TIP...somehow let the next owner know you did this...put a note in the owners manual, put a sign on the fuel tank.. something.
I had a 95 tahoe with the big tank, had to drain and wrestle that thing(still with gas in it, ran out of cars and cans to fill up) after we got the tank out we found the convenient access hole someone else made/used... Glad we dropped it anyway since the previous person hacked up the wiring for some reason.
GoldmistXL
Hello,
Measurements
Thank you so much for posting this. For some reason the photos have disappeared. Can you please post another photo or two showing the location of the access door. Would really appreciate it. Thanks!!!
HiHoeSilver
Away!
Chicago
Hello,
Measurements
The OP probably used a host like photobucket. Uploading directly to the server with the "upload a file" button would be preferable and ensure this great post's longevity.
F
Fixxer
Measurements:
Hole trimming:
Geotrash
Dave
Richmond, VA
Sweet! What tools did you use for the cutting? And, what did you attach the bolts to?
sandspyder
Hello,
I trimmed out the back structure a little too much. The next time, i will leave a little more of a lip to ***** the door down. Save the piece that you cut out- well be using it later.
Measurements
Why isn't it showing the pictures?
How often do you plan on replacing fuel pumps? It takes a half hour at most to drop the tank.
jeremiahm
Way North CA
Depends on how long this Delphi unit holds up! And my back wont put up with all that rolling on the concrete...
jrsroadhauze
Hi, I'm getting ready to change the pump in my 2007 as well. I could not open the pictures to see what you had done. I have the short wheel base not the XL. Any help would be appreciated.
Geotrash
Dave
Richmond, VA
Scroll down on page 1. There are new photos in a subsequent post.
jz57
If the fuel tank is near full, it could take 2 people more than 2 hours to drop the tank, disconnect wires and tubing, and put every thing back in drive-way.
If you have other vehicles you can put the fuel in, you can use either a siphon hose or fluid transfer device and gas cans to empty the tank. Mine was half full and I siphoned it all out. Pull the fill hose off the tank and that gives you direct access to the fuel in the tank. Once empty it weighs about 10 lbs, makes it easy.
a4edwin
ny
I did it on my nbs and ended up breaking the nipple on the charcoal canister when I dropped the tank. Id rather cut an opening if I have to do it on my 07.
X-ray Nerd
