2007 Yukon Denali Fuel Pump Access Door
How often do you plan on replacing fuel pumps? It takes a half hour at most to drop the tank.
jeremiahm
Way North CA
Depends on how long this Delphi unit holds up! And my back wont put up with all that rolling on the concrete...
jrsroadhauze
Hi, I'm getting ready to change the pump in my 2007 as well. I could not open the pictures to see what you had done. I have the short wheel base not the XL. Any help would be appreciated.
Geotrash
Dave
Richmond, VA
Scroll down on page 1. There are new photos in a subsequent post.
jz57
If the fuel tank is near full, it could take 2 people more than 2 hours to drop the tank, disconnect wires and tubing, and put every thing back in drive-way.
If you have other vehicles you can put the fuel in, you can use either a siphon hose or fluid transfer device and gas cans to empty the tank. Mine was half full and I siphoned it all out. Pull the fill hose off the tank and that gives you direct access to the fuel in the tank. Once empty it weighs about 10 lbs, makes it easy.
a4edwin
ny
I did it on my nbs and ended up breaking the nipple on the charcoal canister when I dropped the tank. Id rather cut an opening if I have to do it on my 07.
BWASTEEZE
