2007 Yukon Denali crank no start after driving
Dan Sho
Ok folks here we go. Have a 2007 Yukon Denali. Started acting up a couple weeks ago. Warm it up drive 10-15 miles and it idles down when coming to a stop. Went to back it into a parking spot and dies with a minor idle surge prior. Call tow truck after disconnecting negative cable for ten or so minutes and 20 ish restart tries…crank but no start. Tow truck comes I steer it on and it fires as soon as I touch the key. He follows me to get gas I fill it up and runs fine. Go out later for sales calls after about 20 min of driving stop to get a drink and dies as I pull into the gas station. Push it to the mechanic down the street he messes with it and it eventually fires. Good fuel pressure and spark prior to starting. He ran a bottle of heat through it thinking it might be bad gas. Run around next day with no problems short trips only. Following day drive 25 miles can’t restart. Crank no start. Tow truck shows up. Starts as soon as he gets there. He follows me to his garage. He finds a bad ground coming from the drivers side that goes to the block. When he wiggled the harness It would idle way down. He checks fuel pressure spark etc. all good. Next day drive 120 miles being careful not to shut it off and shifting into neutral and feathering gas at stops. Pull into parking lot at work and it dies. Won’t start for 20ish minutes. Been the same story over and over for the last two weeks. I’ve replaced the tps sensor, cleaned the throttle body, ran trans cleaner through it (as suggested on another forum). THERE HAS BEEN NO DASH LIGHT! The only light I’ve had is stabilitrack shutting of when I’ve been shifting to neutral at stop light after stop light. Which makes sense as it’s shuts off when weird idle is present. I’ll add it has plugs, wires, battery, and starter within the last year as well as a new fuse block under hood from a no crank no start fiasco which was not cheap. In terms of environment I’m in northeast it’s been -15 to 20 out… cold. Changing crank sensor and checking that wiring next any ideas? Please help lol
Welcome to the Forum from NH.
Pics of the truck, please.
I cannot personally help you with your question; however, other members on this Forum that are much more knowledgeable than me will chime in.
Did you put a code reader on the OBDII port and see if there any codes being thrown (that are not visible on the dashboard)?
Dan Sho
Dan Sho
Sorry for the delay. Yes I did hook the scanner on today and it had P0011 in pending codes camshaft position. Not sure if that could anyway be related to me constantly shifting into neutral and keeping the rpm’s up when stopped to keep it from dying. I had the crank position replaced today without any results.
Fless
Moderator
People's Republic of Colorado
Did the shop do a crank position relearn afterward?
Dan Sho
Dan Sho
I cannot confirm that? I will call tomorrow and ask.
Dan Sho
Dan Sho
I will also add that the crank sensor was factory GM sensor
Dan Sho
Dan Sho
I’ll add again also that I dumped a quart of the trans conditioner in like in other threads wilts no change. Hooked up a fuel pressure gauge to see what happens when it dies we’ll see what I get. As of now it’s running 60 at idle. Might try the lower viscosity engine oil trick but being it’s subzero to low teen temps here the last month I have my doubts with that fix. I’m due soon anyway though. Also plan on grabbing a fuel pump relay and monitoring the oil pressure when the problem occurs.
alpha_omega
Michigan
Welcome to the forum from Michigan.
Have you checked ALL of the grounds? There are several on these vehicles that can play havoc and cause weird symptoms. Let us know if you are not familiar with the layout and/or need a reminder of their locations.
Is the service stabilitrak light still on? You could be one of the trucks with the flaky brake pedal sensor. It could also be unrelated and the stabilitrak is something as simple as this: Bulletin No.: PI0639D
Do you still have the heat shields on your exhaust manifold and the starter motor?
Dan Sho
Dan Sho
Not crazy familiar with all ground locations. Stabilitrak light only comes on when I am in stop and go traffic and have to feather the gas in neutral on multiple occasions has always turned of the following trip after a cool down. Ran the scanner three days last week with no pending codes. Heat shield is on the starter. I have not added any additional shielding to the fuel lines yet. I do have the the plastic motor shroud of as it’s the only way to keep my fuel pressure gauge secure while driving. Trying to attach this item by item as I don’t have a garage and don’t get off work until dark.
alpha_omega
Michigan
Talked to the shop. They did not relearn and had no clue what I was talking about….
Hopefully they knew what they were doing when installing it. I’m guessing they didn’t tell you if they checked either of them to ensure they were/weren’t working before hand?
How new is the battery? Have you had it checked? Something a simple as a bad ground or weak connection could become worse from a bad motor Mount or blow shock/air compressor. Then when the vehicle slows down and things shift (the nose dives forward during braking, or you make a turn into a parking lot and the right side/left side angle increases/decreases) your connection could move enough to throw things off.
I’m not saying this is the case, but before you go throwing anymore money into it, I’d say start with the simple things first.
Dan Sho
Dan Sho
Thanks yes I doubt they verified it was toast and I’m guessing it was fine but who knows. The battery is a year old. I agree with the ground issue however it not wanting to start for 15-20 min is odd and since it’s so freaking cold here if I pop the hood it will start even sooner. If I keep it running and shut it of it will restart. If I let it die it’s a waiting game.
Fless
Moderator
Need to get that done, if not for peace of mind. Any time a crank sensor is replaced, a relearn should be done. To skip that step invites misfires in the future.
Wes does one here, start at about 11:10:
Dan Sho
Dan Sho
Sweet thanks yes I agree. Can’t with my scan tool probably have to take it in to do it. Won’t be to the garage that replaced it though.
alpha_omega
Michigan
That’s all helpful info. Remember the more info you can give us and the better picture you’re able to paint, then the better equipped we are when trying to help you get to the bottom of your issue(s).
Your service stabilitrak light sounds like either the TSB link I sent you or the brake pedal sensor. Start with the TSB and checking your grounds.
Grounds:
*Drivers Side (a.k.a. Left or LH)
*Passengers Side (a.k.a. Right or RH)
Rear Left - Inside Bumper mount (go just behind the fuel cap, look under the rear panel and then back toward the bumper. You’ll see two grounds.
Mid Left - Under the drivers door on the frame mount.
Front Left - Check your fuse box to ensure all of your fuses are good. Check the connection at the alternator and the ground strap at the back of the engine.
There are others on the engine block as well as several other locations throughout the vehicle, but the ones subject to movement, rust and corrosion are the main concern. I can send you a list if needed for the others, but let’s not get too ahead of ourselves.
Front Left & Right - Lower left and right of the radiator core support.
You mentioned pressure earlier. Are you seeing a drop in your oil pressure or just your fuel pressure?
What’s the mileage on this vehicle and what maintenance has been done that you are aware of?
alpha_omega
Michigan
Have you taken the battery in to have it tested?
Did everything check out with the fuel system?
That 15-20min lag almost sounds like a fuel pump issue, but im not sure if that would be a concern with it being an ‘07. Someone else can chime in on this one.
60 is high, should be around 44-50 with engine running, not sure if 60 would affect anything but from what I gather that seems high, pre-start pressure should be 60-65
what does the fuel pressure do when it starts to die? is it dropping or staying static?
Dan Sho
Dan Sho
Grounds:
Weather is hopefully gonna break in couple days I’ll check the grounds. 154,000 I’ve owned it for 2 years and in that time Other than fluids I’ve done spark plugs, wires, starter, under hood fuse block with all new fuses (due to no crank no start a year ago) battery, tps , cleaned throttle body, crank sensor, and I think that’s about it. Not seeing any fuel pressure drop just want to monitor it to be sure. Oil pressure does go lower when warm or at stop like 15-20 when at 600 rpm but planning on a better log of that this week. This vehicle was purchased from a previous mechanic who seemed very knowledgeable for whatever that’s worth. Service suspension has been on since I have owned it and airbag light turned on 3k ago still waiting on recall parts for that.
Dan Sho
Dan Sho
Thats why I hooked the gauge on. I’ll find out tomorrow what it’s doing cause I’m not sure. The garage said it was good but I'm past trusting them. I work on the road in sales so I’ll have plenty of time this week sitting and checking after it dies.
alpha_omega
Michigan
Again…all good info for us to know. Thank you for that.
Have you checked the connections at the fuse block to make sure nothing has come loose since the install? Same goes for the wiring harnesses and pos/neg cables.
kikeap
