2007 kon xl Denali towing????
Boysen
Denver, Colorado
Hi guys looking at buying a travel trailer and need to know the towing info for my rig. I have not started to look for one but also have never towed anything with the kon. Still new to the towing world and get confused with all the info that I have read online. Can some one help me understand what I need to be looking for before I start my search for a trailer.
Thanks
Mgyver1
Las Vegas
If your truck has the 6.0L engine w/ 4.10 gears then your max trailer weight is 8,100 lbs with a combined weight w/ fully loaded truck & trailer at 14,000 lbs
Also any trailer at 2,000 lbs or more loaded will need trailer brakes which our trucks are pre-wired for. All you'll need to do is install a trailer brake controller and hook up 2 cables in the fuse box under the hood. Check your owners manual and go onto some towing websites like e-trailer. Also make sure you have a good size transmission cooler, and it would help to have an engine oil cooler too.
veteran111
