2007 Denali Cylinder 6 Oil Foul
Keoder
Apologies if discussed ad nauseam, but I need some help. My 07 has 134,000 miles and I have had cylinder misfires in #6. Pulling the plugs, it’s clear #6 is fouling because of oil. My question is, from what you all know about these 6.2s, is this a bad ring or a valve seat? It takes some time for the plug to go bad and misfire m, but it will eventually.
Thanks in advance for your help.
GMT800 2005 Tahoe Z71
Navy Supporting Member
By, "takes some time", what are we talking about? Need a compression test and a cylinder leak down test. Or just keep throwing plugs in there till you have the extra cash for a teardown and repair.
K
Keoder
I’ve replaced all of them once before...maybe at 115,000 miles. It doesn’t foul up in one or two drives.
Is that common with these engines? Best case am I looking at new valve seals?
donjetman
One yr ago, my 07 Denali 6.2 w/132k miles was burning and leaking 1 oz every 100 miles.
I installed a catch can, did GM TSB# 10-60-01-008M, installed the new improved valve cover, replaced the rear main seal, oil pan gasket, then It immediately stop using any oil. Now 1 yr & 18k miles down the road it still doesn't use any oil. Here are some threads I did that will help you.
https://www.tahoeyukonforum.com/thr...tor-oil-consumption-tsb-10-60-10-008m.108493/
https://www.tahoeyukonforum.com/threads/rear-main-seal-job-pan-etc-07-yukon-denali-6-2.108334/
https://www.tahoeyukonforum.com/threads/valve-cover-change-cleanup.108604/
https://www.tahoeyukonforum.com/threads/sparkies-no-beno.108579/
K
Keoder
So I’ve replaced the oil pan gasket and the rear main already. Not the valve cover gasket.
Will adding an oil catch can make a big difference?
And in your thread where you posted pics of the plugs, mine was like your fouled one but black.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Clogged PCV valve?
donjetman
The valve cover needs to be changed, not the gasket. Read the links I provided. The PVC IS the new improved valve cover, # 12570427 (for my vehicle). There is not a traditional type PVC that can be replaced. What is happening with the original valve cover design is its allowing oil to be sucked from the valve cover, into the intake manifold, into the combustion chambers, where it is partially burnt, but it also causes the pistons rings to become stuck, and then even more oil is consumed because it is able to get by the piston rings. Alas, GM TBM 10-60-01-008M.
The catch can really isn't necessary if all goes well like it did with mine. But I left mine in place and if it ever starts collecting any oil in quantity again, then Houston we have a problem.
K
Keoder
Ah, I see.
If I run a compression test, would I get good reads in each cylinder and thus know for sure it’s a PCV issue?
I’m not savvy enough to put on a new valve cover but I do want to be able to tell the mechanic...”Here’s the issue. Please fix it.”
donjetman
If you can change a tire? you can change the driver side valve cover. DO IT.
If your sparkies look like my sparkies in the link I provided? then you know there is at least an oil control piston ring problem. Compression may still be good, mine was.
I did things a little differently than how the TSB says to do it. I sometimes think I know a better way
and this time it worked out.
First drain the oil and leave the plug out. I took all the sparkies out, squirted Motor Medic by Gunk(AutoZone) in the plug holes, You can get a turkey baster or large syringe(tractor supply) and let it soak in the combustion chambers for hrs, then put a socket and breaker bar on the harmonic balancer bolt, then wiggled it back and forth, then repeat. I did this several times over a whole weekend. Anything that gets by the rings will drain out.
Before putting the sparkies back in, I spun the engine over a lot with the starter to get it all the Motor Medic out of the combustion chambers.
Re-fill with oil. Drive it for 500 miles. Then do an oil and filter change with the best $$ can buy, and hopefully you'll have great results like me.
Did you see the pics of my sparkies?, no codes, no misfires, was running fine, unbelievable right? I cleaned them in my media blast cabinet, and put them back in the engine and they're still firing fine today.
You won't catch me adding any volvent to my crankcase and/or engine oil to break the gunk loose for fear of clogging up an oil passage or something.
View media item 28060
K
Keoder
Thanks Don! I’m gonna take a shot at what you said.
And you think it’ll help even though it’s the #6 cylinder on the passenger side? Man, this seems so much more digestible from a cost standpoint than new valve seals, etc.
26AT4
