2005 yukon xl denali 6.0
Yukonxljake
Looking for info! Have a 2005 yukon xl denali with the 6.0. It has been in and out of the shop for misfire on the initial startup and after sitting for a bit. Once started it runs perfect. Not throwing codes either. The shop replaced the fuel pump, cam sensor, crank sensor, new intake seal, new plugs, new wires, rewired the ecm. They gave it back to me and said they couldn't figure it out! Any ideas? I'm assuming it's a fuel pressure issue, but besides the fuel pump it doesn't have a Fuel pressure regulator, so what else could it be? Thanks!
ks03
Fool Excess Member
Sitting for a bit mean hot soak for 5 minutes, or parked in tall grass?
Could the shop duplicate the concern?
Misfire one one cyl only? Dead miss, or a lil rough? for how long after started?
Y
Yukonxljake
Sitting over night, or for long enough for the fuel system to lose pressure some how. It's not a misfire when running only when going to start. It will turn over for 3 or so seconds without firing, then once I stop and turn it over again it fires right up.
ks03
Fool Excess Member
If you turn the key on for a few seconds before cranking, does it start smoothly, or do the same thing?
ks03
Fool Excess Member
Connected a fuel pressure gauge and know if it is a fuel pressure issue?
Does it do this every or almost every morning?
Keep an eye out on the behavior of the security light.
Any modifications?
Pretty much grasping straws after that unless you get a code to come up sometime
Y
Yukonxljake
Yeah pressure drops after sitting, I cut the security system out all together to see if that was the issue, but was not.
ks03
Fool Excess Member
Tried leaving the fuel pressure gauge on to monitor when starting? Does the pressure come up from keying on?
Some vehicles seem like they don’t fire up the pump until you try cranking, I was thinking you could try to bump the starter and stop, see if the fuel pressure then came up, and then started normally… but I was thinking at some point they made a change and they’ll crank for a few seconds or until they start, even if you let off the key
Y
Yukonxljake
Pressure does increase when it starts, then when you shut it off and go to start it up right after it starts fine. It only happens when it loses fuel pressure
ks03
Fool Excess Member
I mean, have you left a fuel pressure gauge on overnight to see how it’s responding. Does keying on bring fuel pressure up, but then still starts hard?
Y
Yukonxljake
The shop did yes, it loses pressure and then comes up after cranking for 3 seconds or so. I'm on fuel pump number 4
TollKeeper
Brighton, CO
Sounds like a bypassing fuel pressure regulator.. But I thought they did away with those in the 2005 model year..
When you say you replaced the fuel pump. Did you replace the entire assembly, or just the fuel pump?
Y
Yukonxljake
The shop did it, I'm assuming the whole assembly. The 2005 doesn't have a fuel pressure regulator as I've found out. Could a missing cap on the fuel pressure valve up on the rail cause pressure loss ?
TollKeeper
Brighton, CO
It shouldnt, and if it did, you would be spraying fuel.
I am finding conflicting statements about the FPR. Some say the 2005 6.0 did have it, and others say it doesnt.
Autozone does list a FPR for the 2005 Denali
Advance does not
I have seen where people have replaced the fuel pump only, and there is a crack in the plumbing inbetween the fuel pump, and the assembly, causing your exact issues.
Would need to find out if they replaced just the fuel pump, or the fuel pump assembly.
TollKeeper
Brighton, CO
What it would look like if your did have a FPR
Y
Yukonxljake
I watched that video and he's saying it's on the fuel pump itself, I don't think this year physically had one
Y
Yukonxljake
I did, it is not. That's what I am so confused on how it's losing pressure with no FPR and a new fuel pump.
brice715
