2005 Yukon XL Denali 2500?
99bigdreamer
From using search and Google I can't see that the above vehicle actually exists. I'm going to look at a Yukon and it's advertised as a 3/4ton Yukon Denali. Can anyone confirm GM actually made a Yukon Denali as 3/4 ton?
MassHoe04
Western MA
Regular 05 Denali came with 375 h.p. 6.0L, instead of 295 h.p. 5.3L and could tow 8,100 lbs instead of 7,700 lb.
I believe it is still 1500 class truck, but with more hp and towing capacity.
I could be wrong, but I believe the Yukon XL Denali (the longer wheelbase version), same platform as Suburban, was available as a heavier-duty 2500 series.
99bigdreamer
MassHoe04, thanks so much for the reply. I'll try to run the vin through a decoder while checking it out. See if that makes it any clearer
Teamiez
I never have personally seen or heard of a 2500 Denali, all the ones I have seen were just Yukon xl 2500’s with the 6.0 or 8.1 L engine.
Rock Auto lists a 2005 Yukon XL 2500, and it has parts for it. It does not list a Yukon 2500, though.
scottd
