2005 Tahoe wont reverse and makes loud noise in neutral.
Laxinaz
Hey everyone!
I have a 2005 Tahoe 2wd. One day the shift linkage bushing popped off while I was in the drive thru with my family. Luckily it was still in drive so I could take it home. Replaced the bushing and noticed it had no reverse but would drive forward so I drove around the block and it popped off again on the test drive. Got it home by manually putting it back into drive. I attempted to install a new bushing and when I was testing it shifting into gear it still had no reverse and made a loud noise like something was hitting something when in neutral. But the noise stopped when I shifted into reverse or drive. I also have to mention that when I did put it in drive it took a lot for it to move forward like I’d press down on the gas which normally would get it moving pretty quick and it was moving at a crawl. I’m not a mechanic but I’m capable when. It comes to doing repairs myself. If anyone can help me out with some information I’d really appreciate it since I can’t afford to take it to a shop after being in the hospital for 2 months dealing with serious health issues.
Thanks ahead of time.
Welcome to the Forum from NH.
Pics of the truck, please.
I cannot personally assist you with your issue, but other members of this Forum much more knowledgeable than me in this area will chime in.
@OR VietVet @Doubeleive @swathdiver @NickTransmissions
NickTransmissions
Sin City
The transmission bench
Hey everyone!
This sounds like a hard part failure inside the transmission, perhaps gear train and/or sun shell. But that's based solely on your description above. I'd drop the pan and see what's at the bottom. If there's a whole bunch of kibbles and bits, burnt clutch material and the like, put the pan back on with a few bolts and yank it out for overhaul.
brice715
