2005 Tahoe Slow Coolant Loss
Matahoe
Matahoe
Grand Rapids, Michigan
Yea, use the GM coolant leak tabs and nothing else. They work. The others are a 50/50 crap shoot.
Guessing these are the ones?
Matahoe
Matahoe
I put the UV dye in coolant reservoir and didn't add the tabs yet because now I am not sure the coolant is going down now. Just something I noticed. Will keep an eye on it.
GMT800 2005 Tahoe Z71
Navy Supporting Member
It would help to know what, "Just something I noticed". is.
Matahoe
Matahoe
Sure. I went out to the truck the other day and checked the reservoir to add the tab/coolant mixture and the level in the reservoir was normal when engine was cold. When the engine is hot/warm the coolant level in the reservoir is down a few inches. Normal ops? I'm not sure.
Matahoe
Matahoe
Just that one day or over a few days?
No this has been something I have noticed consistently over past years. Coolant level is always an inch or two below the full level mark on the side of the reservoir after engine is fully hot. Temperature on dash is always just below 210 (looks good) but we all know it's not going by the coolant temp sensor exclusively. At least that's what I have gathered in prior posts and searches here.
Matahoe
Matahoe
The surge tank coolant level in my '04 has always gone up (increased) when hot. After a cold soak the level is down maybe 1/2" from the highest level hot. Right at the tank seam when cold.
That's what I would expect as well due to coolant expansion...hence the need for reservoir. It's almost like an air pocket appears only when engine heats up which seems very odd. The coolant gods are playing a trick on me. Hehe.
Matahoe
Matahoe
I don't know maybe I am dyslexic and things seem backwards in my eyes. I will keep an eye on it. Just really scratching my head for the past however many years.
Marky Dissod
Burp it again.
mikez71
I have the same issue with coolant dropping very slowly.. (2012 5.3)
Usually after several months, I look at it, and it's down 3/4" from the full line..
I had rented a coolant tester, pressurized it.. Nothing.
Checked for combustion gasses in coolant, nothing.
I replaced the entire cooling system, minus one little hose and the vent ports..
(I have new hose and gaskets, just need to get around to it)
For now, I'm NOT filling it up to the line. Am going to see if it drops further..
mikez71
I think what is not being considered, like in @mikez71 case, "usually after several months" can be water evaporation. You have a 50/50 mixture and it is not uncommon for some water to evaporate.
But, shouldn't it evaporate into the sealed cooling system and re-condense?
As slow as my leak is, I'm thinking it's a tiny steam leak..
I'm leaning towards one of those steam vent connectors or plugs.
You can't really see the rear vents, but for my '12 model I heard they put a rivet in the hole.
I have some plugs I will put over the rivet with an oring seal... someday when I pull the intake..
Matahoe
Matahoe
Coolant UV dye additive and a black light....
Yes I will check it out now that the uv dye is in. Evaporation? Not likely since the cap will not let pressure out unless overpressure from steam. And there is no steam with coolant unless the cap is removed to lower vapor pressure. It's basically a sealed system.
I watched a few videos. The crossover tube that goes through the throttle body and connects to each head might turn out to be something. There are block offs on the back side of the intake as well so can check. Will get back as soon as I find out more from the black light test.
I checked the reservoir an hour after a 300 mile round trip drive from Detroit to Grand Rapids. The reservoir showed full. But yeah it should be higher. Will check in the morning.
Matahoe
Matahoe
Burp it again.
From what I have gathered here in the forum there really is no need. The system is designed to allow air from the top of the radiator which is the highest point to escape through the hose that goes over the MAF and go directly to the reservoir. Now if you mean to run the engine for a bit while the cap is off? I guess I can do that but not when it's fully hot. I'll check my repair docs and see what the official GM procedure is. Might be a TSB in there or something odd that needs to be done.
kikeap
