2004 Tahoe LT rear door lock issue
rrwidow89
I have a 2004 Tahoe LT. About 6 months ago I started having issues with the rear door locks refusing to unlock using either the driver side door controls or the key fob. You can manually unlock them. Ideas? Thanks in advance!
Big Mama
Virginia
Can you hear any clicking from the door? Take the panel off and try the fob while having a look around.
R
rrwidow89
Nope. There is no noise coming from either side when the remote or driver's door controls are activated...
Big Mama
Virginia
Ok sounds like a power or switch issue. Pop the panel off and do the same. I believe the power comes from the wires under the sill plate.
progar_
I second removing the panel on the rear hatch and visually inspecting the connection to the door lock motor. A broken motor or actuator will usually still make some kind of noise when the corkscrew portion of the innards break. No sound at all sounds like a non connection scenario.
briannorris
