2002 Tahoe- Frame Advice
ScottL
Bought 2002 Tahoe LT new and have taken excellent care of. Another driver hit me, insurance totalled it. Insurance body shop claims the rear passenger side of frame is "twisted 1/4 inch". drives straight, I do not notice. Insurance companies body shop wasn't interested in repairing it either. Is 1/4 inch that big a deal? Advice? Repair? Costs?
Any input appreciated. Thanks.
adriver
Well, it means the title is going to be salvaged. That alone always drops its value a lot. Even a slight tweak could throw off the geometry. It may not be able to be aligned properly, and even though you think its fine, you don't want to suddenly notice the problem at highway speeds. Its just not worth it on a 16/17 year old vehicle that on average is worth between $3-$7K in good shape. You have to find somewhere that can repair the frame and I swear its about $2k just to put on the machine. There has to be more to repair then just the frame, so just making a guess here; Then there is everything else: I'm sure that's some body and paint work, it may be the rear end or at least tweaked the mounts, wheel, brake, paint and body... They are paying dealer/shop charge in labor with new parts for a bill that is going to be more than what its worth, when they will total it out if the repair cost is (I want to say) 60%. I would think best case scenario is you can fix the frame for $1K, then pick all your own parts, do your own mechanical work, and don't care about the body. A picture is worth a thousand words, right now without a picture is worth thousands of bucks.
I would think if you could do all that work, for the time, money, and having a clear title to keep the value, I'd rather pick up a cheap project to swap. I don't know where you are, but here I can find a good Tahoe/Yukon with a bad engine or trans for $1500 (or considering you have everything for a good driveline swap with all electronics, an s10, Silverado, blazer).. I'd swap the good stuff over, and sell the rest to recoup a little.
Unless you've done a lot of aftermarket modifications to it, I would just consider it gone. Get your receipts, and maintenance history in order. Do your best to show the insurance company that it was in the best condition possible, and try to get every last dollar you can out of it. Show them that it was well taken care of, and try to get better than "fair" market value.
S
ScottL
Thanks for info. I kept the truck. In great shape, have all receipts. Replaced trans 6 months ago, brakes, shocks, engine maint. Showed them 10k in receipts for the last 1-2 years. Would only give me 6500, that's with keeping it.
Sent from my Moto Z (2) using Tapatalk
Chubbs
They paid you $6500 after deducting your purchase price?? That’s a win all day long. I had 2004 Land Rover (105k miles) that was mint before a tornado came through. I ended up with like $4500 after buying it back with my orig blue title so it could have been worse.
As suggested before, find another 2002 roller and swap all of your new parts & driveline over. Good to go.
S
ScottL
Thanks chubbs appreciate the input. Yes, 6500 after they deducted salvage value and I kept it. I don't notice any issues driving it. And as I indicated, it is in top condition. New transmission, brakes, ehgine serviced, interior perfect, 160k miles. Can a "1/4 inch twist in the back end" really be an issue? I'm just looking to keep driving it, not sell or anything.
Thanks again.
06JET
Wisconsin
Just keep driving it. You don't need permission. Is it twisted behind the rear axle or in front? Take it to get a four wheel alignment and don't say anything to the shop about the twist. If they can align it then you are good to go.
S
ScottL
I'm just inquiring as far as safety? Just trying to get advice on how safe. It would have to be behind the rear axle.
Thanks.
06JET
Wisconsin
If it is behind the rear axle then it is mostly cosmetic. Rear bumper aligning with the body and such. May make a difference when towing depending on what you would be towing. Personally, I would continue to drive it and figure out how to twist it back myself. You may can remover the rear bumper and spare then get creative with a chain and porta-power and a solid anchor. If it is only $2000 at a frame shop that may be OK. You would still have $4500 from the ins payment. Win-Win.
BTW-I was just messing with you about permission. Good luck.
S
ScottL
No worries man!!! I can take it. I appreciate the input.
select127
Florida
Where is the title? If insurance totaled it for bent frame, new title is gonna say certificate of distruction which i dont think can go back on road.
Take the truck to another frame shop and have them put it up on their machine while you're watching and see where it's at. Don't tell them anything beforehand. I think you'll be surprised.
TheGreatGazoo
Hellinois
Only thing is he’ll need to pay for a set-up & measure. I’d stick with the alignment shop. If it aligns, then you’re good to go. Without a picture i couldn’t tell you much more but my guess is you will be just fine to keep driving it.
Side note, body shops work in millimeters and anything over 3mm is out of spec. That being said, it could be off 300mm but if it’s not in a crucial area to affect the alignment then who cares.
That's true and it does cost money. However, he'll know for sure and know if someone was trying to rip him off or not. The alignment, like you say, is what really matters.
Candielaine
