I did the measurements as directed and turned left and right to check clearances and appears will be just fine. I am looking forward to seeing the difference.
I don’t think they will fit up inside your wheel wells so this will depend on if you’re lowered, stock height, or lifted. If you’re lowered I think you might have issues.
Wheels are such a personal preference. There’s an unlimited number of looks and in the end it’s the owner that has to be happy. I don’t comment if , to me, it doesn’t work because that might be exactly what they were going for and it doesn’t matter that I don’t care for it. But if I like it, I try to be sure to say so. I think you had a vision for what you wanted to do and it came out looking great.I kept getting told that I should go with a wider and bigger wheel/tire combination. I did not want that. More expensive and if have to change a flat the spare would not even be close. I wanted to keep with the same size wheel and tire and yes, I do have plenty of clearance when turning with the positive offset. I personally like it, I should-I paid for them, and in the end that is all I need. Thanks for the comment.
Are the new wheels painted aluminum or painted steel?Ok, I changed my Avatar to the new wheels look. Couple of the new pics compared to the old pics.
View attachment 231262 View attachment 231263 View attachment 231264 View attachment 231265
