2002 Chev suburban LT brakelines abs
Status
Not open for further replies.
Woodblocker55
Ok looks pretty nasty by the abs module and valve . Had brakeline leak to point no brake fluid left .. does ABS need to be flushed or cleaned ? Please advise. Is there a way to test abs so you know it's working right ? Before full hookup .
Sent from my LGL722DL using Tapatalk
Matthew Jeschke
Sahuarita, Arizona
Has pressure haha if you can brake ABS isn't leaking. Seems silly
As for testing computer, no. You need an expensive shop / code reader. My cheapo won't talk to the ABS module.
I hate that they put it where they did on our trucks.
You can do a standard flush, just pump new fluid through the lines.
Sent from my SM-A505U using Tapatalk
Miami-Dade
Moderator Supporting Member
Locked due to double thread.
Status
Conedaddy
