2002 avalanche 2wd
jose6326
Chicago
Does the avalanche have the same abs brake system as the 03 tahoe?
my dad is having issues getting several codes
C0241 - EBCM Internal solenoid or control valve circuit
C0245 - PCM indicated requested torque fault
C0251 - EBCM Internal solenoid or control valve circuit
C0246 - EBCM Internal solenoid or control valve circuit
C0242 - EBCM Internal solenoid or control valve circuit
C0252 - EBCM Internal solenoid or control valve circuit
C0268 - Pump motor circuit open/short
i changed both front hub bearings with speed sensors about a month ago
everything ran fine then the abs & brake light came on
i read that this might be either a faulty control module or bad ground
anyone else have this issue and what was the fix?
i thought i had read on this forum that something had to be resoldered in the electronic part of the EBCM
thanks for any help
bottomline2000
Dallas, TX
I'm not sure of compatibility, but i like to stay within the generation so 00-02 to make things easier. There is a fix to have the brake module reflowed to fix broken connections. Better than buying a new one. I had a bad relay in mine too so my abs pump stayed on even with the truck off. Sent it to a guy on ebay thay fixed and tested it before sending bsck to me. Has been some years since the fix without a repeat of the abs/brake lights.
Sent from my SAMSUNG-SM-T377A using Tapatalk
HeavyHoe03
