1998 Yukon Rear Door Wont open/close
Jazz
Hi all-
And Happy Labor Day! I thought I'd be productive and get the rear door/drivers side open on the yukon. It's been stuck for awhile.
Not sure what else there is to try. Here's the symptoms:
It's partially closed/opened. It'll open about half an inch, but won't fully close either.
The outside handle seems to function. Inside seems to work as well. Same with the lock. The automatic lock appears to unlock it as well.
I removed the panel fully and operated all of the levers. They work.
I've grabbed the levers and tried to open, while someone on the outside lifts the lever as well. I've lifted the door, violently shaken it back and forth to maybe free up the latch.
Nothing seems to work, but everything seems to be working! It seems to me that the latch is simply stuck either with mud/dirt/whatever else. I may have to replace the mechanism. But I can't open the door to do that-
any ideas? I've done a lot of searching, but I can't seem to find anything that would assist in opening this door.
Thanks in advance!
J
Jazz
Hi,
Nope. I can't see the latch mechanism at all. If I could only get a wire in there and pull it back while hitting the handle I could maybe get lucky. But the way these rear doors are designed that's next to impossible.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
well hell i can only think at this point that maybe the door may need to be... well you know. hopefully someone else can comment on this. i know someone went thru this before but forgot who. i think i amount of ideas at the moment.
Gzes
the drifting 2dr
Wichita tx
I'd spray the hell out of it with pb blaster or wd 40 and persuade it open. I've gotten stuck door open like that barn door shouldn't be an acception
J
Jazz
Good idea! I'll spray the heck out of the area as best I can and wait a few days =)
J
Jazz
Grease didn't work. Plan B was invoked. At least it was a happy ending- well, kinda. $160 for the latch. The door is a bit dirty, but hey- we use it :)
SunlitComet
OBS Jedi-Do Good
ugh, what was plan be.
---------- Post added at 08:35 PM ---------- Previous post was at 08:34 PM ----------
i think the latch was gonna happen no matter what.
J
Jazz
Yeah= the 11 year old ninja-in-training crawled inside and kicked it till it popped open. It came to that.. the latch is hard to locate, but I found it for $140 - $20 to 2 day Fedex. Dealer wanted $250.
Deennoek
