1996 2 door Tahoe exhaust
bell5606
I just bought a 96 2 door Tahoe in a auction I found out that the exhaust system was taken off. I was wanting to know would it be better to go with straight pipe or throw in a catalytic converter? I let me know what you think.
Sent from my GT-N7105 using Tapatalk 2
Gzes
the drifting 2dr
Wichita tx
If you like loud then straight pipe it and run a o2 extension so it tricks the computer to think it has a cat. If not then get some flows and a hih flow cat
bell5606
bell5606
Ok thanks bro
ROTNHOE
pa
Going thru same dilema. magnaflow tells me there 23453 wont fit a 2 door,only a 4 door. flowmaster says there #2010023 cats will fit a 2 door. I measured length. sure looks like magnaflow will work. Possibly going to go with flowmasters force 2 cat back system and 1 or the other cat s.:banghead:
SunlitComet
OBS Jedi-Do Good
unknown at this time.
odd a 96 unit is supposed to fit 4 or 2 i thought . it was the muffler section that was shortened for the two door.
just looked again at dealer drawings and part numbers cat are same part 2 or 4 dr. it is the muffler assembly that is different.
bell5606
bell5606
Ok thanks everybody
bell5606
bell5606
I was also wanting to know how many o2 senors does a 96 2 door Tahoe take.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
bell5606
bell5606
Ok thanks man
xanatost
Lafayette, La.
Mine had 4. 2 uppers and 2 lowers. When I had my hoe tuned I got my lowers turned off. At 50 a piece and deleting my lowers I save 100 bucks and if I need to I can all ways turn them back on ;)
bell5606
bell5606
That was exactly what I wanted to know if it would still worked with just two upper o2 senors
SunlitComet
OBS Jedi-Do Good
it can but the rear two just dont monitor the cats they help tweak the fuel trims slightly to make sure the the cats operate correctly and therefore have a better mixture to run off. so they do help a bit the cats that are installed. and state laws are not. removing or gutting your cats are are a federal crime. whether someone looks for them are not.
97Tahoe2d4x
SF Bay Area
Really? They said won't fit 2 doors?
I just installed Magnaflow 45453, California version of direct fit cats on my 2 door, I believe 23453 uses same tubing as 45453 looking at pics and dims. Perhaps they were thinking of the cat-back system?
Straight forward job swapping it out, major PITA is unbolting the stock pipes off the manifods. This is after soaking the crap out of hardware 3 nights in a row with PB blaster.
Little late but hope this helps somebody.....
ASG-MikeS
