153k and poppets are dead and a question
brooks93
Gilbert, AZ
well they finally went. I actually think its the regulator. fuel preasure would drop to 10 lbs after 3 mins of shutting off the engine. Then the truck would be a pain in the ass to restart and when it would fire up it smelled like it was flooded.
so I got the new mpfi spider and since I am taking it all apart the intake gaskets and valve cover gaskets since they where leaking.
question is when I took off the upper intake the front 4 cylinders had alot of oil build up. Is that normal for 153k miles or do I need to look for the source? is it just the egr or a bad gasket somewhere else
B
brooks93
Gilbert, AZ
ya kinda. its right over the cylinder 1,3 but it was the worse over the front 4 cylinders. the back 4 where dirty but not near as bad
oldsalt
At 153k I wouldn't worry about it. You could clean things up with a rag and some brakleen. If you do be sure to stuff some paper towels into the intake ports and the holes for the injectors. Don't forget to take them out though. Clean out the holes for the injectors with a rag around a screwdriver or your little finger before you put in the new ones.
Putting rags or paper towels into any open spots is a good practice to get into anyway just in case you drop something. Even if it's not related to something your working on at that moment. You'd be surprised how far things can bounce sometimes.
Oh, replace the PCV also.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
That is just build up of blowby residue just clean it up. it is a good sign, And like Oldsalt said replace your pcv valve and hose while your at it. They are probably just as dirty and cost maybe $10 for both.
oldsalt
Good point sunlitcomet. Forgot about that. It should be a plastic pipe with a rubber elbow. Get a GM elbow. It'll hurt paying what they want for them but the aftermarket ones collapse under vacuum after they heat up.
B
brooks93
Gilbert, AZ
well scrubbed on it for awhile but got it all cleaned up and looking new. Put all new gaskets and seals on. Dropped in the new spider and bolted it all up. Purrs like a kitten now. No more hard starting and seems like she has a lot more power. Took me 2 days but, had alot of cleaning to do on the upper and lower intake and just checking everything while I was in there. I don't what to have to take it off again unless its a motor swap.
---------- Post added at 07:00 PM ---------- Previous post was at 06:56 PM ----------
what is blow by
SunlitComet
OBS Jedi-Do Good
something that goes over your head when you don't understand it:Big Laugh:
Seriously a wiki explanation. Enjoy. Glad to hear your system is running good again.
As an engine operates, high-pressure gases are contained within the combustion chamber and prevented from passing into the crankcase (containing the crankshaft and other parts) between the side of the piston and the cylinder bore by piston rings which seal against the cylinder. However, some amount of gas always leaks past the piston rings into the crankcase. This amount is very small in a new or properly rebuilt engine, provided that the piston rings and cylinder walls are correctly "broken in", and increases as the engine wears. Scratches on the cylinder walls or piston rings, such as those caused by foreign objects entering the engine, can cause large amounts of leakage. This leaked gas is known as blow-by because the pressure within the cylinders blows it by the piston rings. If this blow-by gas could not escape then pressure would build up within the crankcase.
Before the invention of crankcase ventilation in 1928, the engine oil seals were designed to withstand this pressure, oil leaking to the road surface was accepted, and the dipstick was screwed in. The hydrocarbon rich gas would then diffuse through the oil in the seals into the atmosphere. Subsequently, it became an emissions requirement as well as a functional necessity that the crankcase have a ventilation system. This must maintain the crankcase at slightly less than atmospheric pressure under light load conditions and recycle the blow-by gas back into the engine intake. However, due to the constant circulation of the oil within the engine, along with the high speed movement of the crankshaft, an oil mist is also passed through the PCV system and into the intake. The oil is then either burned during combustion, or settles along the intake tract, causing a gradual build-up of residue inside the inlet path. For this reason many engine tuners choose to replace the PCV system with an oil catch can and breather filter which vents the blow-by gases directly to atmosphere and retains the oil in a small tank (or returns it to the sump), although this technically fails to meet most engine emission legislation.
BlacktopBandit76
