14Bolt SF 4X4.
99COOP
Retired
Chicago, IL
yea i know alot of people who get the 2wd axles by mistake, mostly because they are a whole lot easier to get a hold of. however alot of people also get them to work just fine, but its a little extra work to do so.
blackcoffee
blackcoffee
O.G. Black.
Went to Glick's local junk yard. They couldn't find anything. That's the only place around here =[. Dangit. I checked craiglist. ALL 2WD. And most are 8 lug.
99COOP
Retired
Chicago, IL
^ the 4x4 6 lug 14 bolts are hard to come by, but you will eventually find one you just have to keep checkin in w/ the local salvage yards and keep a few hundred bucks handy and you will get one when you least expect it.
Bad bow tie
Grizz Straight FTMFW
Michigan/NC
You can get one out of a 1500HD 4wd OBS as well. My buddy has one in his 98 Silverado from the factory. Look for RPO code F44 in the glove box.
99COOP
Retired
Chicago, IL
I forgot about the 1500's
why dont u want a full floater? they are way easy'r to change shafts if they break. in my opinion.....
Full floaters create more work, you gotta swap 8 lug to 6 lug hubs, move the spring perches and shock mounts. A SF is usually adequate for 37-38" tires and a much more friendly install. Thats not to say the FF is worse but it can cost more to swap in and unless your running 38+ it's usually not necessary.
Tadsher
